![]() | Home > In Car Electronics > Why did i cut a hole in my dashboard- Wiring help please |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1728 ![]() ![]() |
I've done something silly, which despite taking a cutter to my 2011 puma dash I don't think is the cause!
![]() Basically I've converted my truck cab to a soft top and cut the movement sensor and interior light into the angled side of the centre dash rather than mount a bracket and have loose wires above the screen. When I did this I had the dash out to check it was clear behind (it was honest!) and since putting it back the radio doesn't work other than to eject cd's (its a jvc unit and has power to it) and the interior light has stopped working at the same time. It went a bit mental on the middle setting then stopped. All the fuses are ok so I've obviously ![]() |
All sorted, yes im an idiot luckily it was only the connections that came apart!
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
You should have said mate I have a interior light fabricated plate for soft top propa puma one as we'll laying in the workshop mate
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Cheers mate, might be a bit late for that now! To be fair it looks pretty neat, im going to have to have a good look at all these bits you've got and around the improved workshop! see you then
