Home > Puma (Tdci) > puma fault codes what do they mean
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
hi guys iv checked the ecu for faults today finding a nice list does anyone no what they mean cheers
p167b
p0404
p0606
p0100
p068a
p1103
p0299
p0234
any help greatly received cheers
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #23661 5th Feb 2010 5:40pm
dgardel
Italy
Re: puma fault codes what do they mean
1. p167b = Fuel injector learning not done
2. p0404 = EGR "A" Control Circuit Range/Performance
3. p0606 = Control Module Processor
4. p0100 = Mass or Volume Air Flow "A" Circuit
5. p068a = ECM/PCM Power Relay De-Energized - Too Early
6. p1103 = Mass Air Flow Sensor in Range but higher than expected
7. p0299 = Turbocharger "A" Underboost condition
8. p0234 = Turbocharger "A" Overboost condition
may be
have you remaped? (points 7 and 8 )
Have you blanked the EGR? (points 2, 4 and 6 )
Have you done the P068 patch ECU SW from Dealer but not the last one(P068V5)? (point 1 )
points 3, and 5 could generate by a not 100% battery (when you start up the engine from cold) or reading codes by OBDII Scanner Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #23664 5th Feb 2010 6:09pm
dgardel
Italy
By the way
download this FORD-JLR OBD DTC Codes list
http://files.me.com/daniele.gardellin/vbutqe Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #23666 5th Feb 2010 6:16pm
big steve
ye its remapped but the egr isnt blanked ?
and yes it is spupposed to have all been done as i took it up to pete at bell autos to have it all sorted because the dealer hadnt dne it right
so bit baffling
the alternator decided to charge while the battery light was on so im unsure
thankyou very much for that though
cheers steve 2015 2.2 tdci hardtop xs
Post #23688 5th Feb 2010 8:17pm
big steve
so bit baffling
Post #23689 5th Feb 2010 8:17pm
dgardel
Italy
Have you lag (like little hole or retard) of power when you put 100% accelerator (around 2300-2500rpm)? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #23691 5th Feb 2010 8:25pm
big steve
no doesnt at all pulls like a train i run out of gears lol 2015 2.2 tdci hardtop xs
Post #23693 5th Feb 2010 8:30pm
bell-auto-services
Hi
Steve if i remember correclty we had injector learning problems with your car and assumed so must the dealer have had before me which is why it had problems and you came to me with my offer to try and help, also the faults you post was the faults that was in the car when it came and left.
Did we not come to the conclusion that your car had a possibile wireing fault of a ecu fault and this was the cause of the errors ?
Have you had it back into the dealers since to chq it out further ?
Does the car still drive ok ?
Pete
Post #23694 5th Feb 2010 8:34pm
big steve
hi pete yer it drives fine i just thought id chexk for faults as its just had the gasket replaced in dealer before i put the tune back on and thats what it came up with and was just curiouse what they all meant
im not to worried just waiting for a man that can put me a tdv6 in it Laughing assoon as he gets rounds to it
cheers for all the help guys
and thanks again pete 2015 2.2 tdci hardtop xs
Post #23702 5th Feb 2010 11:05pm
bell-auto-services
Ahh thats cool as long as it still drives fine.
I know a nice man with a TDV6 in a defender, when the soloution is ready ill give you his details hehe Mr. Green
Pete
Post #23703 5th Feb 2010 11:10pm
big steve
i want the engine as well because i have a feeling he will be dropping the new 3.0ltr one in his lol
yer im very keen on it pete as soon as youve completed what you need to do if the price is rightthen ill be having it done
cheers mate
Post #23704 5th Feb 2010 11:16pm
alantd
Pete - I recall you've dropped the 2.7 into a (ex) Td5 Defender.
Presumably it would be more complicated to work it into the new dash and air con configuration of the Puma?
Just keeping my options open Wink One that started out as a 2.4 TDCi 110 XS
Post #23706 5th Feb 2010 11:25pm
