Home > Puma (Tdci) > puma fault codes what do they mean |
1. p167b = Fuel injector learning not done
2. p0404 = EGR "A" Control Circuit Range/Performance 3. p0606 = Control Module Processor 4. p0100 = Mass or Volume Air Flow "A" Circuit 5. p068a = ECM/PCM Power Relay De-Energized - Too Early 6. p1103 = Mass Air Flow Sensor in Range but higher than expected 7. p0299 = Turbocharger "A" Underboost condition 8. p0234 = Turbocharger "A" Overboost condition may be have you remaped? (points 7 and 8 ) Have you blanked the EGR? (points 2, 4 and 6 ) Have you done the P068 patch ECU SW from Dealer but not the last one(P068V5)? (point 1 ) points 3, and 5 could generate by a not 100% battery (when you start up the engine from cold) or reading codes by OBDII Scanner Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 5th Feb 2010 6:17pm. Edited 1 time in total |
5th Feb 2010 6:09pm |
By the way
download this FORD-JLR OBD DTC Codes list http://files.me.com/daniele.gardellin/vbutqe Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
5th Feb 2010 6:16pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
ye its remapped but the egr isnt blanked ?
and yes it is spupposed to have all been done as i took it up to pete at bell autos to have it all sorted because the dealer hadnt dne it right so bit baffling the alternator decided to charge while the battery light was on so im unsure thankyou very much for that though cheers steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
5th Feb 2010 8:17pm |
Have you lag (like little hole or retard) of power when you put 100% accelerator (around 2300-2500rpm)? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
5th Feb 2010 8:25pm |
no doesnt at all pulls like a train i run out of gears lol 2015 2.2 tdci hardtop xs
5th Feb 2010 8:30pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Hi
Steve if i remember correclty we had injector learning problems with your car and assumed so must the dealer have had before me which is why it had problems and you came to me with my offer to try and help, also the faults you post was the faults that was in the car when it came and left. Did we not come to the conclusion that your car had a possibile wireing fault of a ecu fault and this was the cause of the errors ? Have you had it back into the dealers since to chq it out further ? Does the car still drive ok ? Pete |
5th Feb 2010 8:34pm |
hi pete yer it drives fine i just thought id chexk for faults as its just had the gasket replaced in dealer before i put the tune back on and thats what it came up with and was just curiouse what they all meant
im not to worried just waiting for a man that can put me a tdv6 in it assoon as he gets rounds to it cheers for all the help guys and thanks again pete 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
5th Feb 2010 11:05pm |
Ahh thats cool as long as it still drives fine.
I know a nice man with a TDV6 in a defender, when the soloution is ready ill give you his details hehe Pete |
5th Feb 2010 11:10pm |
i want the engine as well because i have a feeling he will be dropping the new 3.0ltr one in his lol
yer im very keen on it pete as soon as youve completed what you need to do if the price is rightthen ill be having it done cheers mate steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
5th Feb 2010 11:16pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Pete - I recall you've dropped the 2.7 into a (ex) Td5 Defender.
Presumably it would be more complicated to work it into the new dash and air con configuration of the Puma? Just keeping my options open One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
5th Feb 2010 11:25pm |
