![]() | Home > Technical > Oil Service Warning |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Just done mine worked as video but didn't get the bong ! But cleared message
![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
stu_007 Member Since: 23 Jan 2014 Location: Cardiff Posts: 99 ![]() ![]() |
My indicator has just come on at less than 3000 miles and it gets mixed driving etc.! Tried reset but this doesn't work! Current
2021 D110 HSE 2013 D90 XS Previous BP07 OZR D110 (1930 YBA) 2007 G4 Mongolian Recce Vehicle BP52GHZ D110 2003 & 2006 G4 Event Vehicle |
It does work, I've had loads of feedback from this and the general consensus is don't rush the process and it'll pay dividends, exactly the same as Sparkylee no bong.
![]() Treat every day as if it is your last....one day you will be right!! |
Ok I'll try again using instructions but video itself no longer exsists on You Tube. Current
Should have been more patient ; all done!! For the record oil level was fine and good colour, I would suggest it wasn't set correctly on PDI!! Current
^^^ Good news...As stated the secret is NOT to rush the process.
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 ![]() ![]() |
G'day guys. Just thought I'd add that I just used the method described by sweepc and it worked first go.
Thanks for posting the instructions sweepc ![]() Mick |
