![]() | Home > My Defender > What did you get your Defender for Christmas? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20619 ![]() ![]() |
Airpusher -
![]() Should have used a hex socket really to avoid damaging the nuts but all was well in the end really. Except when I got a nut stuck in the socket it's self! ![]() Oh and they are gloss black the full works, quite extravagant really on cost especially as they get filthy and could well get scraped badly doing their job. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
I have bought mine a new defender badge for the bonnet DEFENDER XS UTILTY 110 AUTO
ONLY ACCURATE GUNS ARE INTERESTING |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Where did you get that from foxkilla?is it genuine? William
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
Got my 90 a new owner
not genuine but identical got mine in black from spglobalparts on ebay DEFENDER XS UTILTY 110 AUTO ONLY ACCURATE GUNS ARE INTERESTING |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Mine got a 20 mile drive.
First time in 6 weeks. I really need to either use it or lose it. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 ![]() ![]() ![]() |
Mine had a service !!
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 ![]() ![]() |
Mine got its first owner me and a trip into to the white stuff.
Transfer box works and TC checked out ![]() |
993porky Member Since: 01 May 2011 Location: sunderland Posts: 171 ![]() ![]() ![]() |
Got a heated seat kit dreading fitting it as I am not very good with electrics,also got a central locking kit and a polybush kit as well as got a terrafirma 2" lift kit with the big bore shockers, so got myself a bit of work ahead while off work for Xmas hols
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 372 ![]() ![]() ![]() |
I know I felt a bit silly painting them but what the hell! Yes, I've not tried the flange bolts yet mmmm! On another note: another present! 5 x 265/75 Cooper STT's sat in the garage!! ![]() Just waiting to find or save up for some Mach 5's ![]() |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Santa bought a KBX grille and full set of clear LED sides, brakes, indicators, fog, reverse and numberplate lights .. just need to find some time to get out and fit them
My Defender didn't get anything but I got....
Carrotbay - That's pretty much the same as me only I'll have to buy in the coming year, look forward to photos if you take any.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Mine got a tankful of Esso Supreme diesel. Much better & smoother for cold weather/cold engine starting & running at low revs.
And an 'Ardcase pedal case at last. Looks a bit floral now, green case & yellow Disklock when put together. ![]() |
