Home > Td5 > Strange starting conundrum
equipe59
United Kingdom 2003 Defender 90 Td5 CSW Stornoway Grey
Hopefully someone out there on our wonderful forum can help with my starting issue! Confused
It has always started without any problem, but recently it's started playing up. Occasionally I'll turn the key and at Position 1 it's all fine - all idiot lights on etc., then on to P2 and there's nothing at all - all the dash lights go out, no spinning starter, no clicking. Turn off, try again and it may repeat or it may start without any problem!
The battery was a tired, cheapo Halfords unit, so I've changed that for a new genuine Land Rover one, but it's still displaying the same problem Big Cry
My next thought is either the relay, solenoid or engine earth, but I'd welcome any ideas or input as to what the most likely culprit will be before I start taking bits out!
Thanks in advance Thumbs Up
Post #291245 17th Dec 2013 9:06pm
landy andy
Is it high milage? What about warn ignition barrel
Andy
Post #291247 17th Dec 2013 9:09pm
equipe59
Mileage is 130k, but the ignition barrel 'feels' pretty good. It rotates ok, but I'll check the electrical continuity tomorrow evening and see if it's starting to fail.
Post #291250 17th Dec 2013 9:12pm
excossack
Sticking or worn starter solenoid or the small wire has fallen off the back of the starter? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #291251 17th Dec 2013 9:13pm
Laurie
Check the earthing strap on the engine and the battery. Both ends each.
Almost certainly that.
Post #291252 17th Dec 2013 9:13pm
equipe59
Thumbs Up fab, I'll work through it all bit by bit tomorrow and update as to what it was!
Post #291254 17th Dec 2013 9:22pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Dare I ask how much a genuine battery was?
Amazed people buy them
Post #291262 17th Dec 2013 9:43pm
equipe59
A genuine battery was not cheap! Shocked Well over £150, and that's with my discount.
But......it's an 800A/120amp-hr battery, and is substantially bigger and heavier than the Halfords 'original spec' unit it replaced, which was 78amp-hr. The only type of battery I've seen that comes close spec-wise is a light commercial vehicle one, and they're no cheaper and/or the wrong size.
Still, I've found over the years that proper OE stuff generally works/fits/lasts substantially better than pattern bits.
Post #291273 17th Dec 2013 9:57pm
Diablo
Kerrrrist!
I'll stick with my £50 Bosch S5 from Costco I think!
Post #291275 17th Dec 2013 10:00pm
A genuine battery is also the only kind I know which will last over ten years and 200,000 miles, which actually makes it pretty good value in my book!
Post #291285 17th Dec 2013 10:39pm
grafty99
My 2002 90 is on the original battery, I would replace it with a genuine one Thumbs Up
Also it might be worth pulling out the speedo and checking the connections on the back of the ignition barrel 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #291332 18th Dec 2013 8:12am
What about the battery in the remote plipper? and/or the excitor ring thing that's around the ign barrel...
(assuming you've got an alarm set up on yours)... the excitor ring looks for the plipper then "unlocks" the passive immobilisation.
I'd be looking at those first.
Post #291348 18th Dec 2013 9:17am
130dreamer
Had exactly the same symptoms a few months back.
It turned out to be a worn starter solenoid. They are cheap to replace, about £10 from ebay (an ebay search reveals a number of suppliers)
It is an OK job to do yourself if a bit fiddly to get the top starter motor bolt off. If you do a google search there are a number of forum postings on how to remove the td5 starter motor.
Some garages will tell you the whole starter motor needs replacing but the £10 option would be my first port of call.
Post #291377 18th Dec 2013 10:54am
