Home > Puma (Tdci) > Noise killer
Page 2 of 3 <123>
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Tyre wraps? Is this a wind up, or is there actually something to reduce tyre noise available then? Not particualrly bothered by it myself, but certainly intrigued! Mark
2011 110 XS DC
Stornoway Grey
Post #32643 20th May 2010 1:46pm
bob neville
Sure is
Rolling with laughter
They are similar to snow chains Thumbs Up
Bob
Post #32644 20th May 2010 1:56pm
PDH
ive been thinking of reducing road noise as im covering some serious long distance miles lately.
when fitting the noise killer can the standard xs carpets then just fit back over the top? Puma 2.2 90 Stationwagon
Post #32647 20th May 2010 3:03pm
bob neville
They can.
The only problem I had was on the seat box sides - the soundproofing is about 1/4 " thick so it pushes the carpet closer to the door. Add to this the seat belt retaining strips and my drivers door would not close !
I sorted it but cutting a small rectangle out of the soundproof mat behind the strip and this gave me the clearance needed to close the door.
I would suggest trying without this mod first as the passenger side did not have a problem.
I would also get new plastic retaining cups for the carpet studs, half of mine were damaged from new and some of the others got destroyed whan I tried to remove the plastic studs.
Bob
Post #32651 20th May 2010 3:53pm
dgardel
Italy
Bomber82 wrote:
Guys where I can find the under bonnet noise killer kit?
For the interior I will use a particular material that we use in our insulation work that have very high sound proof power.
As soon as I will be back home I will install this material and I will make same acoustic test before and after the application!
http://www.fonosphera.com/fonosphera-sf51.html
(driver side)
I use this one for the "internal side" of the bulkhead, gearbox bell, battery box and fuse box (passenger side) floor and door:
Dynamat XTREME
and this one for the "under-bonnet":
Hoodliner
on the floor, above Dynamat XTREME i put this one
the results are "brilliant"!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32654 20th May 2010 4:26pm
PDH
They can.
Bob
Thanks Bob sound bit of advice, thats my next purchase sorted out when the finances allow Whistle Puma 2.2 90 Stationwagon
Post #32660 20th May 2010 5:14pm
K9F
Gotta be said that fitting an EGR Valve blank will reduce engine noise more than anythig else will!
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32662 20th May 2010 6:33pm
fekete
Its a Defender what do you expect get some of these for your passengers or pump the sounds up Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #32663 20th May 2010 6:58pm
K9F
Karlos I reckon these would be better as it's usually them that are making the racket.... Rolling with laughter
Post #32665 20th May 2010 7:46pm
fekete
Only you could come up with that Rolling with laughter Rolling with laughter Rolling with laughter My birds got one in the bottom draw Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #32671 20th May 2010 9:05pm
K9F
Must have been something good on the telly for you to be away all evening. Mal puts his mischievious head on.... Wink
Has it got batteries? Rolling with laughter Rolling with laughter Rolling with laughter
Post #32674 20th May 2010 9:14pm
fekete
Do you reckon it will fit this
Post #32677 20th May 2010 9:27pm
fekete
Beat this K9 Rolling with laughter
Post #32679 20th May 2010 9:32pm
fekete
Hay K9 how do we get from noise killer to obscene images Rolling with laughter Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #32681 20th May 2010 9:42pm
K9F
Dunno but we're in fer a Censored ' I reckon! Laughing
I keep having to go on my Iphone to see the pictures you're posting. Damn security!
Challenge thrown down and duly accepted! Here goes....
Shocked Shocked Shocked
Post #32682 20th May 2010 9:44pm
Page 2 of 3 <123>
