Home > Puma (Tdci) > Noise killer |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Sure is Click image to enlarge They are similar to snow chains Bob |
20th May 2010 1:56pm |
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 |
ive been thinking of reducing road noise as im covering some serious long distance miles lately.
when fitting the noise killer can the standard xs carpets then just fit back over the top? Puma 2.2 90 Stationwagon |
20th May 2010 3:03pm |
They can. The only problem I had was on the seat box sides - the soundproofing is about 1/4 " thick so it pushes the carpet closer to the door. Add to this the seat belt retaining strips and my drivers door would not close ! I sorted it but cutting a small rectangle out of the soundproof mat behind the strip and this gave me the clearance needed to close the door. I would suggest trying without this mod first as the passenger side did not have a problem. I would also get new plastic retaining cups for the carpet studs, half of mine were damaged from new and some of the others got destroyed whan I tried to remove the plastic studs. Bob |
20th May 2010 3:53pm |
(driver side) I use this one for the "internal side" of the bulkhead, gearbox bell, battery box and fuse box (passenger side) floor and door: Dynamat XTREME and this one for the "under-bonnet": Hoodliner on the floor, above Dynamat XTREME i put this one the results are "brilliant"!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
20th May 2010 4:26pm |
Thanks Bob sound bit of advice, thats my next purchase sorted out when the finances allow Puma 2.2 90 Stationwagon |
20th May 2010 5:14pm |
Gotta be said that fitting an EGR Valve blank will reduce engine noise more than anythig else will!
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2010 6:33pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Its a Defender what do you expect get some of these for your passengers or pump the sounds up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
20th May 2010 6:58pm |
Karlos I reckon these would be better as it's usually them that are making the racket.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2010 7:46pm |
Only you could come up with that My birds got one in the bottom draw NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
20th May 2010 9:05pm |
Must have been something good on the telly for you to be away all evening. Mal puts his mischievious head on....
Has it got batteries? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2010 9:14pm |
Do you reckon it will fit this
20th May 2010 9:27pm |
Beat this K9
20th May 2010 9:32pm |
Hay K9 how do we get from noise killer to obscene images NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
20th May 2010 9:42pm |
Dunno but we're in fer a ' I reckon!
I keep having to go on my Iphone to see the pictures you're posting. Damn security!
Challenge thrown down and duly accepted! Here goes.... Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2010 9:44pm |
