Home > Puma (Tdci) > Low range indicator
David128
Australia 2015 Defender 110 Puma 2.2 CSW Zermatt Silver
Low range indicator
Does anyone have the Low range indicator (green mountain) showing on the dash under the rpm dial when in low range?
Post #23322 31st Jan 2010 10:28pm
alantd
Never seen it. One that started out as a 2.4 TDCi 110 XS
Post #23325 31st Jan 2010 10:34pm
David128
The low range graphic exists, you can see it if you shine a bright light on the box section in the rpm dial. Also the wiring diagrams and electrical library describe the electrical circuit. It looks as though it runs direct and not through the ECU. The description in the manual confirms that there is no bulb check when starting.
Maybe a mid-life enhancement.......pending....
Post #23327 31st Jan 2010 10:44pm
mse
There was a discussion on this some time ago - i would be interested to get it working - i tried...couldnt find where the break to stop it - the switch is in place and the cables seem ok - i wondered if it was just no bulb fitted - but didnt want to remove the clock Mike
Post #23329 31st Jan 2010 11:13pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Why do you need a light to tell you, you're in low range? 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #23341 1st Feb 2010 7:28am
alantd
The amount of times I've been driving down the motorway only to find I'm in low range Thud One that started out as a 2.4 TDCi 110 XS
Post #23345 1st Feb 2010 9:29am
Naks
Really? How on earth do you not realise ur in low when you pull off from standstill!? Shocked
Post #23350 1st Feb 2010 9:52am
David128
Laughing Laughing
From my experience of UK traffic, motorways are perfect for low range….
WRT low range light - curiosity, for the same reason as to why is the driver’s seat belt warning light not enabled although there is a circuit diagram and description in owner’s handbook.
Post #23355 1st Feb 2010 10:50am
dm_td5
Put it in first, ease clutch out and take off like a snail on valium... hmm, must be in first low Laughing
Driving along doing 25mph in 6th gear... 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #23356 1st Feb 2010 10:52am
Grockle
so it's you Derek,causing the tail back on the Stewart Highway Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #23357 1st Feb 2010 11:29am
dgardel
Italy
There is the wired indicator into the dashboard......
There is the connector attached (but not connected, attached on a metal clip) on the right side of the gearbox........
This spring I'll try to do somethings....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #23360 1st Feb 2010 12:00pm
dm_td5
Down here it's the Stuart Highway and its about 680km to the south west of me and currently unreachable by vehicle. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #23362 1st Feb 2010 12:16pm
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Am I right in saying the dials are the same as the D3, I think that could be a leftover.
If i'm wrong, i'm sure someone will highlight the error of my ways. Rolling Eyes
Post #23366 1st Feb 2010 1:53pm
mse
It looks the same but isnt and the press release ones it worked!
As for why do you need it...you dont but then why do you need a winch etc...its a gap there is a light, it has a loose funtion - bingo Thumbs Up Mike
Post #23390 1st Feb 2010 6:41pm
