Home > Maintenance & Modifications > Interior mirror.
Johnnyb0
Interior mirror.
Hi all, the interior mirror on my Puma is pretty crap. When I move the dip lever it moves way past the point where it needs to go and I can see nada. I was hoping to replace it with an auto dipping mirror (either after market or something from another vehicle). Anyone any ideas? Oh, and do the auto dip mirrors need power to work? Thanks.
Post #288709 8th Dec 2013 9:16pm
myonehere
2007 Defender 90 Puma 2.4 HT Cairns Blue
Myself, I use one from the Classic Range Rover [about 1994 MY].. it is autodip and I find the little reading lights in the bottom very useful [urm - bottom of the mirror I mean].
The additional width of view is also invaluable.
Yes, you need power - but can be easily arranged from the interior light.... although that does mean it is 'always live'
Post #288724 8th Dec 2013 9:57pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
YES! There is a very cool mod to do, which so far, only two people (AFAIK) have done - and I was the first one!!! The other is pj2106 (or whatever numbers are after his initials)
I got an auto-dimming compass mirror from a Discovery 2 SE - top top spec - not all SE's have the compass.
I went a slightly different route to pj, as in the trial and error process, I sawed the original Defender mirror off too short.
Here are some pictures:
The mirror has three wires - aside from the obvious earth, one is for an ignition power, so that when you turn the key, the power is lit up, and the other is to connect to the reversing light feed, so that when you select reverse, the dimming function is disabled, to enable you to see clearly when reversing.
The way PJ did it, which was a lot simpler, is to merely keep the original Defender clip in mirror arm, and bolt the D2 mirror to that.
I did have to modify the bracket, as the plug connector tends to want to vacate the arm at the front. I enlarged the hole in the bracket for the plug to be a bit more hidden at the back. 1998 110 300Tdi White Hard Top
Post #288738 8th Dec 2013 10:32pm
geobloke
Interesting. how much bigger is the D2 mirror? Does it fit between the sun visors?
Post #289269 10th Dec 2013 8:09pm
Interlet
This is slight problem. They don't fit between the mirrors, but for the driver at least, you can still put the visor down, it just covers a bit of it. I did think about cutting the visors accordingly, but frankly, it's not unusable how it is now. 1998 110 300Tdi White Hard Top
Post #289274 10th Dec 2013 8:23pm
myonehere
As I said above, I use the Range Rover mirror. If mounted in original position, & as you rightly imply, this would also clash with the sunvisors - but I made a block to fit between bracket and base in order to bring the whole mirror assembly further into the LR and clear the visors.
Post #289293 10th Dec 2013 9:10pm
dgardel
Italy
My job with BMW 3rd series autodim mirror
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #289389 11th Dec 2013 7:28am
cue puns about there being plenty of spare BMW mirrors around as they're never used by their drivers..... Laughing
Post #289391 11th Dec 2013 7:47am
myonehere wrote:
I have the same, with the map reading lights built in ... like hens teeth now though
I have a hardly used BMW auto dipping in my 1 series Thumbs Up
Post #289403 11th Dec 2013 8:30am
Anderzander
I don't ever recall needing to dip / dim the mirror in my 90 ? I had assumed that with being high up I never got any dazzle through the rear mirror.
Post #289405 11th Dec 2013 8:35am
