Home > Td5 > Clutch |
I can't help with a cost, I'm afraid (I'd be nterested to know myself), but the question of a HD replacement came up only recently. The consensus was that it wasn't necessary on a TD5 as some very highly tuned ones were running the standard set up without issue. Darren
26th Nov 2013 6:59pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Hi Tom
I was quoted just over £800 for new Valeo clutch, DMF and a few other bits that are changed as a matter of course from a well respected Indie down here in Somerset earlier this year. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
26th Nov 2013 8:26pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
What he said, £800 sounds about what I paid for clutch, DMF and Ali thrust bearing (rather than standard). Been on now for about 18 months and going well. Engine has JE Engineering remap so puts out a fair bit. First clutch change lasted 6000 miles, last change included a new DMF and I believe that and new clutch plate is the way to go with a remap.
AFAIK you can't get a heavy duty clutch. Spoke to Land Rover and they don't know of any! Spoke to tuning companies and they had not heard of any except for a racing clutch plate upgrade with solid flywheel. They all agreed standard clutch should cope well with even sever remaps. Stick with OEM and replace the lot, should sort you out 2007 TD5 90 Hard Top |
26th Nov 2013 11:56pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
As mentioned above, all the Discovery Td5 boys change the DMF and output seal whilst in there more cost in the beginning, but much cheaper/ reliable for the future.
Glyn |
27th Nov 2013 12:04am |
Tom DCab Member Since: 13 Jun 2013 Location: West Sussex Posts: 33 |
Thanks for the answers on this chaps - the standard clutch should be up to the job then...
So far I have had 2 quotes, both over £1000...including dual mass flywheel, sounds like I should be able to get it done a bit cheaper though so I will keep looking. Tom |
27th Nov 2013 9:23am |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
I can do an upgraded clutch - and still keep the DPF...
Click image to enlarge Uprated on the left - standard on the right. No chatter - it is a solid centre as per the original clutch, and must only be used with a DMF (Dual Mass Flywheel). We do offer a single mass flywheel conversion as well, but even with a sprung centre you do get some chatter on some vehicles. Clutch kit comes with plate, cover, release bearing and spigot. Quote from customer - "cant recommend it enough. its not heavy or harsh to engage. very good pedal feel" This is about as far as you can go with a DPF.... Price for the clutch is £440 + vat But I would recommend a new DMF at the same time.... and then fitting etc. In saying that I have run td5's with 235bhp/535Nm on a standard clutch without an issue.. but they are on the limit. Ian Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
27th Nov 2013 2:30pm |
My defender went infor a new clutch today
Had a call this afternoon to say that the clutch and flywheel were contaminated with oil from a leak... After closer inspection it turns out that it was a diesel leak from the fuel pressure regulator. So I have a new clutch and flywheel but the garage have not replaced the regulator, but have tightened it up..?! I need to make sure that this doesn't happen again. Can anyone advise whether it is best to replace the entire regulator or whether it is sufficient to just replace seals / gaskets on regulator? Thanks Tom |
9th Dec 2013 6:06pm |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
Regulator and gaskets
changed gaskets only on mine earlier this year only to find that diaphragm leaked in portent to tighten fixing bolts right torque if you can use LR Parts good luck |
9th Dec 2013 6:57pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
Whole thing .
Got mine from Guy Salmons ebay shop. This was the best price for a Genuine part (not sure if there are pattern ones). Not hard to change, but fiddly. Easier if you remove the hoses from the regulator body before removing the bolts. Expect to think of many names for the pesky bottom bolt! |
11th Dec 2013 8:19am |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
If you remove the the metal hose fittings from the regulator body access to the lower bolt is a doddle. 2005 Td5 90 XS
Steve |
11th Dec 2013 9:04am |
Thanks guys..
So entire new regulator.... Seen genuine LR ones on Ebay for £135...From Lr £175... Tom |
11th Dec 2013 9:15am |
