Home > Td5 > Clutch
Tom DCab
United Kingdom 2003 Defender 110 Td5 DCPU Oslo Blue
Clutch
Hi
My clutch is slipping quite a bit (TD5 89,000 miles) - been getting gradually worse for about 6 weeks now. I think the time has come to bite the bullet and get it fixed!
Does anyone know what a realistic cost is going to be for a new clutch to be fitted and flywheel if this needs replacing too?
Also, my Defender has stage 2 remap, and was wondering whether I need to think using any 'heavy duty' clutch parts with this being the case...? Any advice on this would be much appreciated.
Thanks,
Tom
Post #285443 26th Nov 2013 6:22pm
I can't help with a cost, I'm afraid (I'd be nterested to know myself), but the question of a HD replacement came up only recently. The consensus was that it wasn't necessary on a TD5 as some very highly tuned ones were running the standard set up without issue. Darren
Post #285454 26th Nov 2013 6:59pm
bob neville
Hi Tom
I was quoted just over £800 for new Valeo clutch, DMF and a few other bits that are changed as a matter of course from a well respected Indie down here in Somerset earlier this year.
2013 Defender 90 CSW - sold
Post #285490 26th Nov 2013 8:26pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
What he said, £800 sounds about what I paid for clutch, DMF and Ali thrust bearing (rather than standard). Been on now for about 18 months and going well. Engine has JE Engineering remap so puts out a fair bit. First clutch change lasted 6000 miles, last change included a new DMF and I believe that and new clutch plate is the way to go with a remap.
AFAIK you can't get a heavy duty clutch. Spoke to Land Rover and they don't know of any! Spoke to tuning companies and they had not heard of any except for a racing clutch plate upgrade with solid flywheel. They all agreed standard clutch should cope well with even sever remaps.
Stick with OEM and replace the lot, should sort you out Thumbs Up 2007 TD5 90 Hard Top
Post #285578 26th Nov 2013 11:56pm
Glynparry25
As mentioned above, all the Discovery Td5 boys change the DMF and output seal whilst in there Thumbs Up more cost in the beginning, but much cheaper/ reliable for the future.
Glyn Dog Sheep
Post #285579 27th Nov 2013 12:04am
Tom DCab
Thanks for the answers on this chaps - the standard clutch should be up to the job then...
So far I have had 2 quotes, both over £1000...including dual mass flywheel, sounds like I should be able to get it done a bit cheaper though so I will keep looking.
Tom
Post #285639 27th Nov 2013 9:23am
Porny
Site Sponsor
I can do an upgraded clutch - and still keep the DPF...
Uprated on the left - standard on the right.
No chatter - it is a solid centre as per the original clutch, and must only be used with a DMF (Dual Mass Flywheel).
We do offer a single mass flywheel conversion as well, but even with a sprung centre you do get some chatter on some vehicles.
Clutch kit comes with plate, cover, release bearing and spigot.
Quote from customer - "cant recommend it enough. its not heavy or harsh to engage. very good pedal feel"
This is about as far as you can go with a DPF....
Price for the clutch is £440 + vat
But I would recommend a new DMF at the same time.... and then fitting etc.
In saying that I have run td5's with 235bhp/535Nm on a standard clutch without an issue.. but they are on the limit.
Ian
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #285687 27th Nov 2013 2:30pm
Tom DCab
My defender went infor a new clutch today
Had a call this afternoon to say that the clutch and flywheel were contaminated with oil from a leak...
After closer inspection it turns out that it was a diesel leak from the fuel pressure regulator.
So I have a new clutch and flywheel but the garage have not replaced the regulator, but have tightened it up..?!
I need to make sure that this doesn't happen again. Can anyone advise whether it is best to replace the entire regulator or whether it is sufficient to just replace seals / gaskets on regulator?
Thanks
Tom
Post #288916 9th Dec 2013 6:06pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Regulator and gaskets Thumbs Up
changed gaskets only on mine earlier this year only to find that diaphragm leaked Mad
in portent to tighten fixing bolts right torque
if you can use LR Parts
good luck Thumbs Up
Post #288939 9th Dec 2013 6:57pm
kipperthedog
Whole thing Thumbs Up .
Got mine from Guy Salmons ebay shop. This was the best price for a Genuine part (not sure if there are pattern ones).
Not hard to change, but fiddly. Easier if you remove the hoses from the regulator body before removing the bolts. Expect to think of many names for the pesky bottom bolt!
Post #289401 11th Dec 2013 8:19am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
If you remove the the metal hose fittings from the regulator body access to the lower bolt is a doddle. 2005 Td5 90 XS
Steve
Post #289416 11th Dec 2013 9:04am
Tom DCab
Thanks guys..
So entire new regulator....
Seen genuine LR ones on Ebay for £135...From Lr £175...
Tom
Post #289423 11th Dec 2013 9:15am
