![]() | Home > Maintenance & Modifications > salisbury diff |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
The bearings either side of the main diff assy are 607187 (same both sides)
You may/may not need the shims to adjust the backlash, which are: 0.003" 607188 0.005" 607189 0.010" 607190 0.030" 607191 In theory you shouldn't need to alter the pinion bearing, just leave it be (I didn't when I fitted the ARB to my salisbury) PM me your email and I'll send over the workshop manual pages for the axle. Edit: just worked out how to add files to my gallery, so either go to my gallery, or click this and open in a new page |
stevetd5 Member Since: 15 Aug 2007 Location: Adelaide Posts: 37 ![]() ![]() ![]() |
Downloaded from your feed thanks.
