Home > Stolen > Ram Proof Retractable Drive Posts
Page 2 of 2 <12
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Mine was fitted due to having a evo v111 that was quite a collectors car .
At 550 brake hp .
It also had autocate fitted which meant I could text the engine off after it had gone 500 yards .
This only happened once and was found just down the road sirens blaring all the doors open .
Gits nicked my soft mints off the dash though Thumbs Up
Post #285071 25th Nov 2013 12:00pm
Albert s
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I thought I was ok
I chain up my 90 to a secure ??? fixing point with a 3" link chain approx 6mm
The wife went out the other day and set off and the chain broke ,the damage was the towing bkt
Electric plug.
I now chain it tighter so she/thieves cannot get a run at it . Evil or Very Mad
Post #285174 25th Nov 2013 6:51pm
Likeomg
i also thought about a sturdy anchor point in the grown and a large chain around the towing gear (our boat is secured in this method), fortunately mine lives in a large very secure garage with 5 high quality cctv cameras.
Post #285178 25th Nov 2013 6:57pm
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Albert's post demonstrates the easy power. I am sure the driveway lockpost will act as a deterrant but if someone really takes a fancy to ur landy a post will not stopit on average giventhe average driveway foundations. I install massive posts on industrial estates and for descorts still knockthem out. I now rely on delay deterrants and its much much more effective. I hope everyone ofthemworks tho and hope im totally wrong!!
Post #285516 26th Nov 2013 9:17pm
Albert s
My best purchase
I park my 90 on a locked gated drive with the chain previously mentioned
However the best thing I have installed is a sensor (wireless) with the alarm
In the bedroom . I park with the sensor directed at the 90 and if anybody walks
Passed or moves the landi the chime sounds.
To date approx 3months I have had no false alarms except when the landi is not
On the drive and I see all movement on the neighbors drive.
Brilliant buy at approx £36 off ebay. Cool
Post #285604 27th Nov 2013 7:44am
jimbob7
@ Albert s /\/\/\Bin lookin fer somethin like that, have you a Linksy?? Pov.spec,ftw. 2006, 110,TD5.
Post #285652 27th Nov 2013 10:56am
Albert s
This is the one to try
£31.99 FROM EBAY
DIGITECK NEW WIRELESS DRIVEWAY PATROL GARAGE SHED DOOR SHOP BURGLAR ALARM ALERT
Dont forget to mount PIR so it is looking at Defender only and point it high to miss cat/dogs
mine is located at a height of approx 5ft from ground and works perfect, can set it to chime or alarm.
Brilliant Thumbs Up Thumbs Up
Post #285700 27th Nov 2013 3:31pm
Tiger
I have a telescopic post sank 1.2m into concrete.
Just drops down into the ground when not in use
Post #285705 27th Nov 2013 3:52pm
Caterham
Perhaps something like this......
&desktop_uri=%2Fwatch%3Fv%3DFJJTjPsSV_Q
Post #285748 27th Nov 2013 6:31pm
Caterham
I've been thinking of putting a chain around one of the wheels like it was a bike?
Post #285749 27th Nov 2013 6:34pm
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
I use a chain, 19mm (bar diameter) hardened steel links. The chain is attached to a large hollow lump of concrete under the block paving. Chain sits inside the hollow when not in use and is accessible through a gas stop tap cast iron lid.
To try and resolve the issue of a determined thief trying to drive off I park so that the chain is behind the 90 and looped over back axle.
The only way out is backwards, the chain has more strength than the pull of the 90 and if the concrete lump gets pulled out of the ground it is big enough to foul the underside making getaway difficult if not impossible.
I also have a security light that has a wireless alarm, came from marlin.
Post #285822 27th Nov 2013 10:02pm
Page 2 of 2 <12
