![]() | Home > Td5 > pressure in a cold expansion chamber |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Exactly the same symptons as I just had with my project90.
Cracked head. ![]() ![]() It steadily got worse. start the engine and the top coolant hose would be rock solid in about 15 seconds. Then if I put my foot down, it would blow out the top of the expansion tank. Then it burst a hose, and blew another one off the radiator. I changed the head then. all seems good now with a replacement head. On the plus side, it's quite easy to change the heads over on Td5's. |
steven Member Since: 20 Sep 2013 Location: weil der stadt Posts: 10 ![]() ![]() ![]() |
Thanks, D.J. I suspected as much. Guess the son and I will replace the head. Any recommendations for a good manual to follow, and a good parts supplier? Would be nice to have a comprehensive list of everything I need so I can buy everything together and then just get it done.
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
I'd 2nd that request - a good 'head swap' guide would be deeply appreciated ...
Orangeboy Member Since: 24 Sep 2013 Location: Uk Posts: 48 ![]() |
Think turner eng sell a fitting kit with everything in , just not sure if it fits just there new heads
http://www.turnerengineering.co.uk/acatalo....html#a445 |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
FYI,pretty sure general consensus is to buy genuine LR headgasket. Pov.spec,ftw. 2006, 110,TD5.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
which was a blessing for us this year in Croatia when we changed one before the comp even started! change the engine a day later ........ ![]() you soon get bored doing it in the rain under canvas! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
kharnsflair Member Since: 17 Sep 2013 Location: South Posts: 12 ![]() |
Hi all,
This thread has me thinking ( ![]() So, how much pressure in a cold expansion chamber is too much pressure and a sympton of a problem? Thanks. |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
Mine held pressure & occasionally I could hear bubbling but couldn't see them, eventually it started to use coolant (very small amounts) then eventually did the same as diesel Jim's.
from Turner & Co. They had it here in only 2 days. Was going to install it myself last weekend, but never got the time. A local garage will have it starting tomorrow. I'm looking forward to seeing what kind of a difference it makes, having a head that doesn't leak. I've come to the conclusion mine has leaked since I got it, a year or so ago.
A thread back from the dead - but finally got mine into a garage, and the head gasket it going. The head is off to be tested.
Expensive day to the workshop. |
