Home > Puma (Tdci) > Gearbox Oil/change
symmo
2007 Defender 90 Puma 2.4 XS CSW Rimini Red
Gearbox Oil/change
Defender 90 XS 2007 Puma. Is it easy enough to change the Gearbox/Transfer box oil, are there any filters? what oil? and where do you fill it from, or anything I need to know. Thanks for your help in advance.
Post #22725 22nd Jan 2010 3:54pm
dgardel
Italy
http://www.defender2.net/forum/post19142.html#19142
http://www.defender2.net/forum/post19041.html#19041 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #22736 22nd Jan 2010 7:47pm
MK
Castrol BOT 328 is GL-4 Evil or Very Mad Puma 110" SW
Post #22741 22nd Jan 2010 8:59pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Transfer case is Castrol Syntrax 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #22750 23rd Jan 2010 1:53am
MK
Yes, same viscosity range and fully synth as Castrol BOT328, but GL-5. Puma 110" SW
Post #22751 23rd Jan 2010 2:09am
MartinK
Guys - I need a bit of help here! I'm just ordering the fluids for an early-life oil change.
Happy on Engine and Diffs (already got these in my Opie checkout waiting to buy). Not too confident on the Gear box or transfer box. Suggest I'll stick with (or as close to) manufacturer recommendation especially whilst in warranty.
Transfer Box:
The OPIE site recommends the Castrol product: Castrol Axle EPX 80W-90 (formerly EPX 80w-90) gear oil
There's no data in my manual.
Gearbox:
Manual recommends Castrol BOT 130M - as others have stated - can't find it!
Castrol Website says Syntrans Multivehicle 75W-90
OPIE site says Castrol Universal 75w-90 semi-synthetic gear oil (formerly Castrol Syntrax universal)
Am I being overly fussy? At least on a R380 it was always MTF94...there's too much choice?
Any ideas/advice please? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #92943 6th Oct 2011 12:52pm
MK
Tbox: 75W90 or 80W90 GL-4 or GL-5
Gbox: 75W90 GL-4 (not GL-5)
that is all you need to know.
Synthtetic last longer than mineral. Puma 110" SW
Post #92945 6th Oct 2011 1:00pm
MartinK
Thanks, MK, that's what I thought having read the forum, but the Opie site says:
Quote:
Benefits of Castrol Universal 75w-90 semi-synthetic gear oil (formerly Castrol Syntrax universal)
Castrol Universal 75w-90 meets the need for a 'universal' gear oil which can be used in automotive manual gearboxes, transaxles, transfer boxes and final drives where stringent performance specifications including API GL4 or GL5 must be met.
So Opie are recommending an oil for the Gearbox which meets GL5... Not sure I feel confident about buying it...
Think I need to buy the GBox oil elsewhere... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #92949 6th Oct 2011 1:40pm
Lorryman100
I use Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil in the transfer box and Millers Oils CRX 75w90 NT Competition full synthetic transmission oil for the gearbox. As for the diffs I use either a generic gear oil (Molytex EP90), Millers Oils Classic Differential Oil 90 (Formerly Classic EP 90 GL5) or the Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil, all available from opie oils Thumbs Up
    Capacities:
    Front diff : 1.7litres
    Rear diff : 110 = 2.26litres, 90 = 1.7litres
    Transfer Box: 2.3litres
    MT82 Gear Box: Initial Fill = 2.4litres GL4 Fully Synthetic, Service Fill = 2.2 litres
HTH Brian.
Post #92951 6th Oct 2011 1:50pm
MK
For the Gbox ask him any of these GL-4 oils:
Syntrans Transaxle 75W-90
Syntrans Multivehicle 75W-90 Fully Synthetic MTF
Iīm sure they have Amsoil but they are expensive me thinks Puma 110" SW
Post #92952 6th Oct 2011 1:52pm
symmo
Gearbox oil
You can get the Casrol BOT oil from a Ford parts dealer.
Post #92973 6th Oct 2011 3:41pm
MartinK
Thanks all. Order at Checkout ready to place:
Castrol Magnatec 5W-30 A1 Fully Synthetic Engine Oil – 8 Litres
Castrol Axle EPX 80W-90 – 4 Litres (1.6 litres in each axle)
Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil – 3 Litres (Transfer Box, needs 2.3l)
Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF – 3 Litres (Gearbox needs 2.4l)
I'll order it on Monday as I want it to arrive on Wednesday...Already bought filter at my local LR dealer. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #92980 6th Oct 2011 3:57pm
ZeDefender
I believe the "official" line is that a gear oil change needs 2.2l as the "full" capacity is 2.4l but 0.2l remains trapped inside - if I'm wrong please tell me (doing mine soon - using Motul Gear 300) Wink Tell someone you love them today because life is short.
Post #93004 6th Oct 2011 5:23pm
Lorryman100
That is correct Thumbs Up Initial fill is 2.4litres when new and then in service drain and fill is 2.2litres.
Post #93007 6th Oct 2011 5:36pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Gear oil GL 4 and GL 5 together?
Hi guys,
I bought mobil mobilube 1 shc sae 75w90 fully sysnthatic oil for both gear box and transfer case. The spec says,
Mobilube 1 SHC 75W-90 meets or exceeds the requirements of the following industry and builder specifications:
API GL-5/MT-1
ZF TE-ML 07A
Scania STO 1.0
Mobilube 1 SHC 75W-90 has the following builder approvals:
JSC AVTODIZEL YaMZ Gearboxes
MAN 341 Typ E3
MAN 341 Typ Z2
MAN 342 Typ M3
MB-Approval 235.8
ZF TE-ML 02B/05B/12B/16F/17B/19C/21B
Mobilube 1 SHC 75W-90 is recommended by ExxonMobil for use in applications requiring:
API GL-4
ZF TE-ML 08
http://www.mobil.com/UK-English-LCW/heavyd...5w90.aspx#
Can this oil be used on my puma both gear and transfer case as it has properties of GL4 and GL5?
Cheers !
Regards,
Diluk
Post #219193 15th Mar 2013 3:27am
