Home > Puma (Tdci) > Melted jammed ignition switch.
AndyAus
Australia 2012 Defender 110 Puma 2.4 SW Fuji White
My puma has just melted and destroyed its second ignition and starter in a week. Is this a common problem? Is there something else in the electrcals causing this to happen?
Post #280953 10th Nov 2013 12:25pm
AndyAus
Problem fixed. The second key set door key would turn the ignition but wouldnt allow the key to spring back to the second position.
Post #281348 11th Nov 2013 8:17pm
munch90
Was the starter running all the time .. Also might worth checking starter relay in case that is damaged too
Post #281360 11th Nov 2013 8:45pm
