Home > Puma (Tdci) > Melted jammed ignition switch. |
AndyAus Member Since: 28 Oct 2013 Location: Pointe Noire, Republic of Congo Posts: 9 |
Problem fixed. The second key set door key would turn the ignition but wouldnt allow the key to spring back to the second position.
11th Nov 2013 8:17pm |
Was the starter running all the time .. Also might worth checking starter relay in case that is damaged too
11th Nov 2013 8:45pm |
