Home > Maintenance & Modifications > Lazer Lamps wiring query |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 |
Has anyone changed or done the wiring of the Lazer Lamps on their defender differently as to what it says on the information diagram?
2nd Nov 2013 8:36pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Which Lazer Lamps and what are you trying to achieve?
Brendan |
3rd Nov 2013 10:08am |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
Nope, i did it exactly as instructed and they work really well.
3rd Nov 2013 10:10am |
They are the RS4's. Did you use the standard bolts, or security ones?
3rd Nov 2013 10:54am |
Security bolts
3rd Nov 2013 1:00pm |
Security bolts. You could always use a drop of locktite and silicon in addition.
Brendan |
3rd Nov 2013 4:19pm |
One quick query,and that is:
Do you need the ignition cable from the relay? the reason i ask is that i haven't got mine connected and funnily enough the lights aren't working despite everything else being wired in as the diagram says! |
16th Nov 2013 4:05pm |
