Home > Off Topic > impact guns
Page 2 of 2 <12
Mdm
I've used aeg.milwaukee with great reliability
Currently using a cp2400 .loads of torque and good battery life.
But a snap on gun has a wee bit more oomph and trigger feel @ a price though
Post #278699 1st Nov 2013 10:40pm
DOOFER
I've got the snap on gun at work. But I'm thinking of a Milwaukee for home. I've given up with dewalt, the drills just don't last Sad
Post #278700 1st Nov 2013 10:49pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Ok a little more help please. Some of these are giving a maximum bolt size that they will drive like say 12mm or 16mm, what does that mean? Rhubarb and custard let fly with their secret weapon.
Post #278955 2nd Nov 2013 10:29pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Are you looking at impact drivers or impact wrenches??? 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #278968 2nd Nov 2013 11:00pm
As far as I know when a max bolt diameter is quoted it is on the basis of typical recommended torque for that size, ie if M16 is stated as max bolt size it means you are unlikely to have enough power to torque an M20 fitting.
There is of course no reason why you couldn't use a suitable torque multiplier if you needed to.
Post #278972 2nd Nov 2013 11:13pm
lambert.the.farmer
Impact wrench es .
Ok that makes sense cheers.
As it turns out I have been looking at my compressor and it seems it may have enough free air to run some of the guns out there which opens up a whole new level of tool fetishism. Rhubarb and custard let fly with their secret weapon.
Post #279007 3rd Nov 2013 8:13am
aled
How suitable is the CP2400 for removing rusty nuts and bolts around a Defender chassis? More importantly, how likely is it to shear off the head of a typical M6 bolt? CP2400s are available at a reasonable price (£120ish), or would I be better off, i.e. safer, with a compact lower torque impact driver. My ratchets and spanners are failing to shift some nuts/bolts; but this is likely to be an occasional use tool, hence the desire to keep the costs low.
Thanks in advance
Post #475663 24th Nov 2015 2:31am
Page 2 of 2 <12
