![]() | Home > Technical > NO POWER |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 ![]() ![]() ![]() |
Do not panic, it happens too us all, you need Q058V5 update to your software, take it in and tell the dealer what happened and he will put the software patch on. The car will be fine and the light will go out after a while.
Most people have had this generally before the car get fully warm ![]() ![]() 110 HCPU Tipper |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 567 ![]() ![]() ![]() |
Dunno if that is the same (the MIL and lost of power can have multiple causes, so better take your car to the dealer to check what is the actual error code), but just in case, did you check these posts?
http://www.defender2.net/forum/topic1834.html http://www.defender2.net/forum/topic2333.html http://www.defender2.net/forum/topic2288.html |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Easiest way is to call Land Rover Assist and get a Land Rover Tech to come out (not AA) Get them to check the car over. They will recommend a visit to the dealers if required. If its un drivable or not safe to drive the car will be collected and you will/should be given a Land Rover product whilst yours is being repaired.
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 ![]() ![]() ![]() |
cheers guys 90 now in dealers getting sorted will keep you informed
Got my 90 back it was what you all said it was but all sorted now not much different it seems a bit smoother just glad it was nothing to serious thanks again
