Home > Puma (Tdci) > a few things ?
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
a few things ?
firstly iv got a horrible squeel coming from my turbo has any one else exsperianced this if so what was the outcomes
secondly after off roading the other week my alternator light came on so at this point i thort best to go home but when got home checked it with a meter and it was still charging surely this cant be rite can it
only seems to happen when theres mud about ?
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #22057 13th Jan 2010 10:32pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
had a big pile of fine silty mud get in my altinator and the light stayed on until LR warrenty changed it.
Post #22065 14th Jan 2010 12:57am
AndrewS
Are you sure the squeal is from the turbo? Could it be the drive belt that is loose, thats also causing your charging issues Thumbs Up
Post #22070 14th Jan 2010 8:55am
RED-DOT
Drive belts have a sring loader tensioner which keeps the drive belt tensioned perfectly from tdi to Puma. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #22081 14th Jan 2010 12:13pm
AndrewS
Yes they do Thumbs Up and they also go weak cause the above problem and need replacing Thumbs Up
Post #22082 14th Jan 2010 12:26pm
RED-DOT
Maybe on a million miler Tdi but not a TD5 or Puma? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #22084 14th Jan 2010 12:51pm
AndrewS
Had mine changed at 12k on the Puma Thumbs Up
Post #22092 14th Jan 2010 1:35pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Got to be worth a check hasn't it, cheap and easy fix if it is Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22093 14th Jan 2010 1:45pm
RED-DOT
Yip.. for sure!! I have a BMW with "efficient dynamics" which among other things has the stop/start feature but it hasn't worked since october... called BMW and there was a list as long as my arm for the stop/start to stop working... if the battery is not in full charge and under +4 degrees and if you ar running a lot of electrics. I then asked if the alternator was not up to keeping up and he said a big capacity alternator would use more fuel. I give up. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #22094 14th Jan 2010 1:55pm
big steve
its deffo the turbo im 100%
and how did LR do the alternator my light doesnt stay on all the time only ifi get mud init but then it clears itself Confused
Post #22142 14th Jan 2010 10:55pm
jst
from 300 tdi they had them. 200tdi didn't. bearings in them collapse anyway. i had one go on a td5. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #22262 16th Jan 2010 7:38pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I know of plenty of TD5`s that had to have the tensioner changed and not a million miles Thumbs Up Discocuzzy had his changed due to the squeal which was really annoying
Post #22266 16th Jan 2010 8:52pm
double cab happy
steve
LR did the alternator because even after 15 min with a jet wash aimed at the altinator and 150 nervous mile drive home the light was still on, i have to admit and don't tell LR, that i gave the defender the clean of its life an told them it was a road side puddle...........but sssssssssssss i didn't tell you that.
Post #22295 17th Jan 2010 8:06pm
