Home > Wheels & Tyres > grass tyres |
scotsstag Member Since: 17 Jun 2012 Location: D+G Posts: 535 |
Hankook Dynapro AT, great tyre for your needs and reasonably priced for 205-16's.. 04' 90 Td5 CSW..
3rd Oct 2013 5:24pm |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Ok ta. I'll have a look at them and see what happens. Cheers. Rhubarb and custard let fly with their secret weapon.
3rd Oct 2013 7:07pm |
Whilst your idea of buying tyres that you can properly wear out during their theoretical life before exposure kills them makes sense on paper, in the real world you may have a problem.
The performance of a tyre isn't constant right up to the point that it's worn down to the wear bars. It will drop off significantly long before then. For your particular use, an AT with 7mm of tread, whilst potentially still having lots of life in it as a road tyre, will perform a lot less well on grass than one with 12 or 13mm. I can't tell you how quickly any given tyre might become worn to the point of being ineffective - your mileage and over all useage will determine that - but it's worth bearing in mind before just diving in for a cheap option in the hope that you can wear it out over five years or so. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
4th Oct 2013 7:35am |
I know what you mean about the performance dropping off and honestly I would change my tyres way more often but I am constrained by it being the farm car and therefore not wholly mine to treat as I would. Consequently tyres have to be worn out before they are changed which has led to some pretty knackered tyres being kept on various cars well after they should have been discarded. It's just one of many issues to come from working with family. Rhubarb and custard let fly with their secret weapon.
4th Oct 2013 11:44am |
Ah, I see your problem. In that case, the best advice I can give is to try and get the best AT that you can afford. Darren
4th Oct 2013 11:56am |
