Home > Td5 > Clutch judder and odd part found in bell housing
Orangeboy
First hello all , always found good answers here so thought I best join.
The clutch on my td5 110 has stared to judder a lot when pulling away
At first I thought fpr but can't find it leaking
The. I removed the wadding plug from the bell housing to see what fluid might be in there.
All that dropped out was a round ball bearing ?
Where could it be from , the release bearing maybe ?
Thanks
Post #269132 24th Sep 2013 7:20pm
I would have thought release bearing. as this is a proper bearing.
Not sure what is inside the DMF, but i'm sure it's mainly rubber and big springs, no bearings.
Post #269137 24th Sep 2013 7:30pm
RILEY
United Kingdom 1994 Defender 90 Td5 CSW Stornoway Grey
Sad Thats the gearbox out then (better sooner than later"now")if one's fell out they all will pretty quick Big Cry one life, sell it
Post #269139 24th Sep 2013 7:34pm
theorangebandit
If I had anything that looked like acomponant id have the box off straight away with a fresh brew and call in sick fo. Three days
Post #269145 24th Sep 2013 8:03pm
theorangebandit
Post #269146 24th Sep 2013 8:04pm
Orangeboy
Thanks all, my skills don't stretch to gearbox removal and I lack anywhere to work on it other than the street.
Guessing if I'm paying some labour it might be worth doing the clutch at the same time ?
And would a bearing failing cause the judder ?
Sorry lots of questions
Post #269152 24th Sep 2013 8:18pm
theorangebandit
Theres no bearing on the clutch face so it shouldnt creat judder but. theres a chance tg. Release bearing isnt detatching correctly if its damaged. Cars a fun one tiny feature can cause something totally random. Are you local to suffolk?
Post #269155 24th Sep 2013 8:26pm
Skye_Rover
Scotland 1998 Defender 110 300 Tdi CSW Cairns Blue
If the clutch judder is only when you are just engaging the drive, with your foot still on the clutch pedal, then you might well have a dodgy clutch release bearing. Even if the bearing isn't breaking-up, you can still get a judder from a rough bearing. There is no point just replacing the release bearing if you are paying for the labour, you need to find a good LR indy who can do the whole 3-piece for you (bearing/cover/plate). A good indy would also be able to make an assessment of the DMF while the clutch is off. Thumbs Up Roads? Where we're going, we don't need roads.
Post #269253 24th Sep 2013 11:21pm
Orangeboy
Im south west.
Yep the judder is only when tou start to lift the clutch. If i pull away with a good amount of revs it ok but just lifteing the pedal slowly to pull away on ticker over is very bumpy.
When I found the loose ball I was kind of resigned to a big bill.
It's on 140000 and I have good history going back to about 80000 miles
And no mention of a dmf being changed
Found a small hole in the foot well too , at least that's a cheap fix
I have an indie close by that I trust so off to see them on my way to work
Post #269269 25th Sep 2013 7:13am
Orangeboy
An update.
Yep the release beraing had failed but the juddering was the flywheel
After a big bill and new clutch kit dmf spigot etc its all back and gear changed are smoother than ever since I got it
Post #274889 18th Oct 2013 6:30pm
Skye_Rover
Glad you got it sorted! It's great when you can get a Defender back to the way it should be, rather than let it slip into being a nightmare to drive. A bit like having a new car.....every month.... Rolling with laughter Roads? Where we're going, we don't need roads.
Post #274950 18th Oct 2013 10:16pm
Anderzander
Can I ask which clutch and DMF kit you went for ?
Post #274967 18th Oct 2013 11:03pm
