![]() | Home > Maintenance & Modifications > Mud Defenders Fitted! do they work UPDATE |
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 ![]() ![]() ![]() |
Now fitted, as above not sure how to post photos on here. But have used bigger rivets as the stock ones were a bit weedy through chequer plate.
Also unlike photo above have used mastic to fill I'm cracks, if you do not do this the wet watery mud can still get through from below. Only slight worry is in the event of a mild side swipe they may not give. I doubt these will come off in the snow, but easy enough to replace of they do. |
All work was carried out whilst vehicle was being waxed by Mick Pickett of UnderBodyProtection.co.uk
in Lindfield, Haywards Heath, East Sussex. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge [/img] |
Budget version......
