Home > Maintenance & Modifications > Mud Defenders Fitted! do they work UPDATE
Page 3 of 3 <123
Ianl
here's mine fitted with checker plate and side steps
(well it would be if i could get photos to upload , or photobucket was working today)
my mud flaps are fitted wider than standard so i had to trim them a bit
driver side looked a better fit before i bent the step into the sill
Post #290589 15th Dec 2013 7:20pm
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Now fitted, as above not sure how to post photos on here. But have used bigger rivets as the stock ones were a bit weedy through chequer plate.
Also unlike photo above have used mastic to fill I'm cracks, if you do not do this the wet watery mud can still get through from below.
Only slight worry is in the event of a mild side swipe they may not give. I doubt these will come off in the snow, but easy enough to replace of they do.
Post #299259 16th Jan 2014 6:45am
Peter
Attached to chequer plating
All work was carried out whilst vehicle was being waxed by Mick Pickett of UnderBodyProtection.co.uk
in Lindfield, Haywards Heath, East Sussex.
[/img]
Post #299531 17th Jan 2014 9:11am
Laurie
Budget version......
Post #299590 17th Jan 2014 12:43pm
Page 3 of 3 <123
