Home > Technical > LED Problems |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
That's done with the 'third wire' that is connected to the sidelights
26th Sep 2013 10:50am |
Ah, ok. In a similar vein then, does it still work if LED sidelights are fitted? Darren
26th Sep 2013 11:43am |
As said, that isn't a 'voltage sensing' function, the sidelight circuit is a 'physical' connection
26th Sep 2013 11:50am |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1217 |
I have the Flatdog bumper....through Matt
I extended the positive right through to the positive terminal on the battery. I connected the earth to the Headlamp earth. I have left the sidelight connection isolated. As soon as I turn the ignition the LEDs come on. If I start the engine they stay on. If i leave ignition on but dont fire up they switch off after a short delay. When swtiching engine off the LEDs go off after a 5 second delay. All works fine for me! Clemmo PS there is no legal requirement to switch off or dim DRLs on an aftermarket install..Only OEM. DRLs should go off when the headlights are switched on. http://www.theaa.com/motoring_advice/safet...ights.html Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
26th Sep 2013 12:15pm |
Got it. Thanks Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
26th Sep 2013 4:08pm |
