Home > Technical > LED Problems
Page 2 of 2 <12
That's done with the 'third wire' that is connected to the sidelights Thumbs Up
Post #269551 26th Sep 2013 10:50am
Ah, ok. In a similar vein then, does it still work if LED sidelights are fitted? Darren
Post #269558 26th Sep 2013 11:43am
As said, that isn't a 'voltage sensing' function, the sidelight circuit is a 'physical' connection
Post #269560 26th Sep 2013 11:50am
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I have the Flatdog bumper....through Matt
I extended the positive right through to the positive terminal on the battery.
I connected the earth to the Headlamp earth.
I have left the sidelight connection isolated.
As soon as I turn the ignition the LEDs come on. If I start the engine they stay on.
If i leave ignition on but dont fire up they switch off after a short delay.
When swtiching engine off the LEDs go off after a 5 second delay.
All works fine for me! Thumbs Up
Clemmo
PS there is no legal requirement to switch off or dim DRLs on an aftermarket install..Only OEM.
DRLs should go off when the headlights are switched on.
http://www.theaa.com/motoring_advice/safet...ights.html Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #269567 26th Sep 2013 12:15pm
Got it. Thanks Thumbs Up Darren
Post #269602 26th Sep 2013 4:08pm
Page 2 of 2 <12
