Home > In Car Electronics > DC whip
landy andy
DC whip
Any advice/pictures of where to mount CB whip on a double cab 110".
Normally got a 5' thunderpole whip.
Andy
Post #266988 15th Sep 2013 6:16pm
GUM97
What back are you planning on putting on it? A mate of mine has a DC, and has his mounted on the rear quarter panel of the tub, just to the left of the drivers side rear brake light Thumbs Up An engine to TDi for!
Post #266999 15th Sep 2013 6:34pm
landy andy
Thanks,
Will keep fabric tilt at first, but probably will go for a Trojan back in time and after much saving.
Also not sure if whips have progressed since my last install.
Andy
Post #267002 15th Sep 2013 6:40pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Off Topic I like the look of the Trojan back any ideas on prices as may have to add a hard back some time
Post #267004 15th Sep 2013 6:48pm
ARC99
This is the location of mine, which I fitted with quich release on a spring.
 Don't make old people mad.
Richard
Post #267007 15th Sep 2013 6:53pm
landy andy
Same as mine on my 90. But new double cab has not got the flat section at the rear of the roof
Post #267012 15th Sep 2013 7:21pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
What about a gutter mount for the time being?
I am very jelous andy Thumbs Up 2004 TD5 Defender 90 xs station wagon
Post #267020 15th Sep 2013 7:39pm
landy andy
Gutter mounts always come off whilst off road and then cause damage, so it's a no for them.
But I have found this
http://www.4x4cb.com/public/item.cfm?itemID=2105
Which can be mounted at different angles compared to the standard base mount.
Post #267022 15th Sep 2013 7:45pm
landy andy
Info here
http://trekoverland.com/article02.html
Post #267025 15th Sep 2013 7:46pm
Retroanaconda
The type of mount above fits a truck cab/double cab. Just mount it below the gutter line. The coil of the aerial can rub on the gutter if it's a wider coil, so best if it's one of the slimline ones as shown there.
Had that setup on my 90 for a while when it was a truck cab.
Post #267026 15th Sep 2013 7:47pm
johnszs
Would you mount it on the rear of the roof or c pillar (next to the rear quarter windows) 2004 TD5 Defender 90 xs station wagon
Post #267027 15th Sep 2013 7:49pm
landy andy
Thanks. That's what I was thinking. Other option is wing mount, opposite mount position to fm ariel.
Post #267029 15th Sep 2013 7:51pm
johnszs
Front wing mount would be good but range would be reduced slightly, but atleast you wont have to worry about low trees etc 2004 TD5 Defender 90 xs station wagon
Post #267030 15th Sep 2013 7:54pm
landy andy
Yes thought range would be reduced by this position, so thought would upgrade from standard whip to high power one.
Any one any experience of them?
Post #267034 15th Sep 2013 8:02pm
johnszs
Just a thought you could get a small amp for your cb which will greatly improve things 2004 TD5 Defender 90 xs station wagon
Post #267037 15th Sep 2013 8:05pm
