![]() | Home > In Car Electronics > Best size/weight for auxillary wiring - and where to buy ? |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
Am looking at adding one of the little six fuse units into my 90 to provide power for the sub-woofer, rear camera, work light, front spots, etc and was wondering what size/weight of wiring to use:
A) from the battery to the fuse box B) from the fuse box to any of the remote units - eg rear work lights or to the front spots C) to any relay units that might be needed along the way ! Any thoughts or recommendations ? Thanks Jon |
lots out there, including
www.polevolt.co.uk RS.com mobilecentre can sell you fuse boxes etc |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
Yet to be installed, but I have a 2 x 6 Gang aux fuse box. I'm going to run a 35A relayed line to each bank, then 16-25A (Have lots of that around) of to each device.
Both relays will be run from the *hopefully* spare ignition line on the back of the barrel! As to suppliers, PoleVolt and Vehicle Wiring Products are my choice (VWP are reasonably local'ish). |
