Home > In Car Electronics > Best size/weight for auxillary wiring - and where to buy ?
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Am looking at adding one of the little six fuse units into my 90 to provide power for the sub-woofer, rear camera, work light, front spots, etc and was wondering what size/weight of wiring to use:
A) from the battery to the fuse box
B) from the fuse box to any of the remote units - eg rear work lights or to the front spots
C) to any relay units that might be needed along the way !
Any thoughts or recommendations ?
Thanks
Jon
Post #265421 10th Sep 2013 10:17pm
excossack
I went with 16amp thin wall when I did mine for all the wiring. (earths, power feeds etc) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #265571 11th Sep 2013 10:05am
lots out there, including
www.polevolt.co.uk
RS.com
mobilecentre can sell you fuse boxes etc
Post #265601 11th Sep 2013 12:08pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Yet to be installed, but I have a 2 x 6 Gang aux fuse box. I'm going to run a 35A relayed line to each bank, then 16-25A (Have lots of that around) of to each device.
Both relays will be run from the *hopefully* spare ignition line on the back of the barrel!
As to suppliers,
PoleVolt and Vehicle Wiring Products are my choice (VWP are reasonably local'ish).
Post #270177 29th Sep 2013 4:23pm
