Home > In Car Electronics > Fuse box wiring - Positive supply |
I fitted a 60amp in-line fuse off the battery and ran that to a single auxilliary Blue Sea fusebox. Ran in a spare cable at the same time in case of future additional circuit requirements.
See page 2 of this thread, pictures too..... http://www.defender2.net/forum/topic20439-15.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Sep 2013 12:50pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5877 |
I remember that post. Maybe a bit OTT for me. Like the idea of it though 1999 Defender TD5 110
10th Sep 2013 12:53pm |
You can buy battery terminals with mega fuses built in, from there take it to a fuse box with a common +ve and -ve rail, talk to Tim at MobileCentre, he's got a good selection of kit
10th Sep 2013 12:58pm |
As long as the wire is suitably sized, then yes there's no reason why that won't work. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
10th Sep 2013 2:50pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Looping in and out is 'correct' but really laborious and increases the possibility of a connection coming apart.
I too used the Mobile Centre Blue Sea fuse box (two infact), highly recommended |
10th Sep 2013 3:05pm |
