Home > In Car Electronics > Fuse box wiring - Positive supply
excossack
Currently for the additional fuse boxes I have each fuse has its own feed take direct from a single point. With the additional wires its a bit messy. I was thinking of replacing all the wires with one or two feeds into the fuse box
Starting off with the first fuse and then loop in and loop out to the next fuse.
Would this be a suitable method? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #265164 10th Sep 2013 12:39pm
K9F
I fitted a 60amp in-line fuse off the battery and ran that to a single auxilliary Blue Sea fusebox. Ran in a spare cable at the same time in case of future additional circuit requirements.
See page 2 of this thread, pictures too..... Thumbs Up
http://www.defender2.net/forum/topic20439-15.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #265169 10th Sep 2013 12:50pm
excossack
I remember that post. Maybe a bit OTT for me. Like the idea of it though 1999 Defender TD5 110
Regards
John M0VAZ
Post #265171 10th Sep 2013 12:53pm
You can buy battery terminals with mega fuses built in, from there take it to a fuse box with a common +ve and -ve rail, talk to Tim at MobileCentre, he's got a good selection of kit
Post #265172 10th Sep 2013 12:58pm
Re: Fuse box wiring - Positive supply
As long as the wire is suitably sized, then yes there's no reason why that won't work. Darren
Post #265217 10th Sep 2013 2:50pm
Looping in and out is 'correct' but really laborious and increases the possibility of a connection coming apart.
I too used the Mobile Centre Blue Sea fuse box (two infact), highly recommended Thumbs Up
Post #265219 10th Sep 2013 3:05pm
