Home > In Car Electronics > is the radio aerial electric
Page 2 of 2 <12
Interlet wrote:
How does that work, I swear my aerial which is standard (although on the Censored quite a bit) is lower than my roof line!!!????
Not being funny but have you checked each section is fully extended - lower sections can stick before being fully extended, especially if you pull it up from the top.
Post #265378 10th Sep 2013 9:36pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I'll look in the morning. I'm usually pretty aggressive when I pull it out...it certainly won't last, and I expect I'll be getting a replacement soon! 1998 110 300Tdi White Hard Top
Post #265417 10th Sep 2013 10:59pm
ericvv
Well, mine clearly is not. When I drive into my office car park, the fully extended aereal just touches to entry door, but the rear of the truck misses it by several centimeter..... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #265432 11th Sep 2013 12:28am
Interlet
I guess my aerial is pretty bent and twisted then. I know it's not in the best of nick, but mine sits about an inch or so short of the roof! Useless thing!! Twisted Evil 1998 110 300Tdi White Hard Top
Post #265434 11th Sep 2013 12:32am
Grockle
x-isle wrote:
I went for the "cheap" upgrade suggested by another forum member.
Got one of these > http://www.ebay.co.uk/itm/270955002855?ssP...9106484653
Then extended the standard aerial out, cut it off quite low down, screwed in this new aerial into the exising one. Crimped it tight and pushed the remains of the standard aerial back in.
Works a treat and looks so much better.
I'll take a close up photo, but you can see it on this photo
Is that Bonsall in the picture ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #265687 11th Sep 2013 4:55pm
bear100
May be a daft question Shocked can the 110 itself be used as an aerial? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #265788 11th Sep 2013 8:52pm
in a third rock from the sun sort of way?
Post #265803 11th Sep 2013 9:19pm
bear100
Anyone know? 2023 Defender L663 V8
Post #266445 13th Sep 2013 9:37pm
Tiger
Quote:
Yay! my upgrade I think
http://www.defender2.net/forum/topic18023.html
Post #266482 13th Sep 2013 11:00pm
x-isle
Yes, Tiger, it was yours that I stole! Laughing
Grockle, yes it's Bonsall. I had just done some lanes and stopped to use the public toilets. Needed after the very narrow lane (Moor Lane) we'd just gone down....... Shocked Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #267101 16th Sep 2013 6:46am
theorangebandit
I like the standard old fashioned arial I think it fits well with the timeless image of the defender. I have put thought toward mounting a CB ariel of similar size on the opposing arch in the same place giving a symetrical set up. Also as another member pointed out the top of that standard ariel is a height indicator as with nothing on the roof on standard springs the top is I think just over level with the peek of the roof si
Post #267257 16th Sep 2013 7:59pm
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
alfred. wrote:
Nakatanenga have this:
http://nakatanenga-tours.de/shop/article_N...tenne.html
I installed the Blaupunkt antenna but did not want to have it at the the top side of the front window and therefore put it on the down side: reception is alsmost useless. Any good experiences with the Blaupunkt or any other window antenna? 2021 Defender 110 D300 HSE
Post #270178 29th Sep 2013 5:31pm
Page 2 of 2 <12
