Home > In Car Electronics > is the radio aerial electric |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
I'll look in the morning. I'm usually pretty aggressive when I pull it out...it certainly won't last, and I expect I'll be getting a replacement soon! 1998 110 300Tdi White Hard Top
10th Sep 2013 9:59pm |
Well, mine clearly is not. When I drive into my office car park, the fully extended aereal just touches to entry door, but the rear of the truck misses it by several centimeter..... You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
10th Sep 2013 11:28pm |
I guess my aerial is pretty bent and twisted then. I know it's not in the best of nick, but mine sits about an inch or so short of the roof! Useless thing!! 1998 110 300Tdi White Hard Top
10th Sep 2013 11:32pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Is that Bonsall in the picture ? 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
11th Sep 2013 3:55pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1939 |
May be a daft question can the 110 itself be used as an aerial? 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
11th Sep 2013 7:52pm |
in a third rock from the sun sort of way?
11th Sep 2013 8:19pm |
Anyone know? 2023 Defender L663 V8
13th Sep 2013 8:37pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Yay! my upgrade I think http://www.defender2.net/forum/topic18023.html |
13th Sep 2013 10:00pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Yes, Tiger, it was yours that I stole!
Grockle, yes it's Bonsall. I had just done some lanes and stopped to use the public toilets. Needed after the very narrow lane (Moor Lane) we'd just gone down....... Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
16th Sep 2013 5:46am |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I like the standard old fashioned arial I think it fits well with the timeless image of the defender. I have put thought toward mounting a CB ariel of similar size on the opposing arch in the same place giving a symetrical set up. Also as another member pointed out the top of that standard ariel is a height indicator as with nothing on the roof on standard springs the top is I think just over level with the peek of the roof si
16th Sep 2013 6:59pm |
kjmeijer Member Since: 09 Apr 2012 Location: Netherlands Posts: 84 |
I installed the Blaupunkt antenna but did not want to have it at the the top side of the front window and therefore put it on the down side: reception is alsmost useless. Any good experiences with the Blaupunkt or any other window antenna? 2021 Defender 110 D300 HSE |
29th Sep 2013 4:31pm |
