Home > Maintenance & Modifications > Cleaning up chequer plate
excossack
I cleaned up the chequer plate on the 110 ready to be re-sprayed. I tried using a nylon rust remover attachment on the drill, while this worked it was slow going. So I tried a short tear-drop shaped wire brush attachment which worked better between the the treads but still took a while.
Is there a quicker way/better way? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #264700 8th Sep 2013 8:58pm
Leenorthants
Brick acid! Spot on.
Post #264713 8th Sep 2013 9:11pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Brick Acid - Does that really work? if so, how does it leave the surface afterwards? .. any residue left ?? Cheers,
Superspoons
Post #264717 8th Sep 2013 9:26pm
Leenorthants
My mate swears by it, you need to experiment a little with the strength, but worth a try.
Post #264720 8th Sep 2013 9:28pm
superspoons
Any ratio's ? 50/50 ? 25/75 ? Just something to start with would be great Thumbs Up Cheers,
Superspoons
Post #264728 8th Sep 2013 9:52pm
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
I used G101 and an old scourer, came up really nice...
Post #264733 8th Sep 2013 10:13pm
Lou Sparts
A friend of mine used to use a product called ali clean on his unpainted luton body with good results,Sorry dont know a supplier though. 2005 Td5 90 XS
Steve
Post #264735 8th Sep 2013 10:21pm
excossack
Does brick acid remove paint as well? 1999 Defender TD5 110
Regards
John M0VAZ
Post #264760 9th Sep 2013 7:09am
K9F
Yes! If it removes mortar sand and limescale it will most certainly damage your paint. Find something more paint friendly.
I would possibly try something like this on a test area and have a hose ready to wash it off immediately it comes in contact with the paint perhaps?
This looks good but I would mask off well beforehand......
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #264765 9th Sep 2013 7:45am
excossack
I have a test bit of ally so can practice on that.
As long as the surface is paintable after using brick acid, that would be good. 1999 Defender TD5 110
Regards
John M0VAZ
Post #264770 9th Sep 2013 7:57am
How about alloy wheel cleaner? Darren
Post #264772 9th Sep 2013 8:10am
excossack
I've got some of that as well Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #264774 9th Sep 2013 8:12am
jimbob7
The pro's use an acid cleaner on alloy tanks,they come up like new.
Post #264775 9th Sep 2013 8:28am
SGH
I used this on the rear body of my 110 tipper...
http://britishchemicalproducts.co.uk/product.asp?P_ID=145
Post #264788 9th Sep 2013 9:17am
That did indeed look really good - have to wonder what the magic ingredients are Shocked
Would be interesting to know whether the newly cleaned surface stayed clean or actually deteriorated really quickly and so needed more and more frequesnt treatments to retain the clean look.
Post #264835 9th Sep 2013 12:53pm
