![]() | Home > Maintenance & Modifications > Cleaning up chequer plate |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Brick acid! Spot on.
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
Brick Acid - Does that really work? if so, how does it leave the surface afterwards? .. any residue left ?? Cheers,
Superspoons |
My mate swears by it, you need to experiment a little with the strength, but worth a try.
Any ratio's ? 50/50 ? 25/75 ? Just something to start with would be great
![]() Superspoons |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
I used G101 and an old scourer, came up really nice...
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
A friend of mine used to use a product called ali clean on his unpainted luton body with good results,Sorry dont know a supplier though. 2005 Td5 90 XS
Steve |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5899 ![]() ![]() ![]() |
Does brick acid remove paint as well? 1999 Defender TD5 110
Yes! If it removes mortar sand and limescale it will most certainly damage your paint. Find something more paint friendly. I would possibly try something like this on a test area and have a hose ready to wash it off immediately it comes in contact with the paint perhaps? This looks good but I would mask off well beforehand...... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I have a test bit of ally so can practice on that.
As long as the surface is paintable after using brick acid, that would be good. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
How about alloy wheel cleaner? Darren
I've got some of that as well
![]() Regards John M0VAZ Econet Station 48 no clock |
The pro's use an acid cleaner on alloy tanks,they come up like new.
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I used this on the rear body of my 110 tipper...
http://britishchemicalproducts.co.uk/product.asp?P_ID=145 |
That did indeed look really good - have to wonder what the magic ingredients are ![]() Would be interesting to know whether the newly cleaned surface stayed clean or actually deteriorated really quickly and so needed more and more frequesnt treatments to retain the clean look. |
