Home > Td5 > Td5 aircondition overheating please help
Carolos1973
Cyprus
Hi,
My LR 90 td5 ( ecu remapped) when going uphill with air con on after a while it overheats the car and looses power.I immediately switch off air con and temperature goes normal.
Why is this happening, what do i need to see.? Please help
Post #264208 6th Sep 2013 9:13am
Check which way the fan is running? If backwards then it'll be drawing heat from the engine bay out across the radiator.
I once had a viscous fan fitted backwards on a V8 and it would overheat at low speeds Rolling Eyes Darren
Post #264216 6th Sep 2013 9:26am
