![]() | Home > Td5 > Td5 aircondition overheating please help |
Check which way the fan is running? If backwards then it'll be drawing heat from the engine bay out across the radiator.
I once had a viscous fan fitted backwards on a V8 and it would overheat at low speeds ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
