![]() | Home > Maintenance & Modifications > Squeaky clutch?.....Easy mod! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
I’ll have to have a look again shortly. Thank you. WeWillWin🇬🇧🇺🇸
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 122 ![]() ![]() ![]() |
This is on my list of jobs and fingers crossed!
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Question. Tried to do this mod Today (whilst waiting for the paint to dry), but can i screw in the nipple on both sides?
Left is for my the easier side but could’t screw it in. At long last i succeded to take a Photo of the left side. Any ideas? ![]() Click image to enlarge a defender from 1984 pretending to be a puma with a touch of Range Rover |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
You can or can't screw the nipple?
I am not sure what you mean when you say both sides? For me there was just one place where the nipple could/would go... ![]() Click image to enlarge > 110 XS Double Cab |
In my perspective this is the right side. But i drive a lhd car and the right side of the clutch box is hard to reach so i would like to screw in the nipple on the left side of the clutch box a defender from 1984 pretending to be a puma with a touch of Range Rover
Ah I understand, but unfortunately I can't offer any additional help on the problem. Mine screwed in very easily. Good luck! > 110 XS Double Cab
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Did this mod last week and for the first time in a long time have a squeak free clutch. Also fitted a power spring. Fiddly, but well worth it.
Not sorted yet. Does anyone have a spare Black clutch box of which they can take a Photo on both sides?
Or has anyone done this mod on a lhd car?? a defender from 1984 pretending to be a puma with a touch of Range Rover |
Have a look here. Might provide some info
https://www.lrworkshop.com/parts/SKB500280 and https://www.lrworkshop.com/diagrams/land-r...edal_45162 > 110 XS Double Cab |
The axle (part nr 272712), at least how i look at it, isn’t symetrical. My assumption now that this axle can be switched but you need to get out this box.
Just a long shot ![]() Ps thnx hank a defender from 1984 pretending to be a puma with a touch of Range Rover |
Hank - How did you manage to fit the angled grease nipple? On mind the thread was much smaller than that so only could fit the smaller grease nipple at 90 dregrees ofset from the side of the clutch box wall.
Did you enlarge the threads? Or were they present already. If the latter much have different to mine. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
It didn't feel like a particularly positive thread engagement when I screwed the grease nipple in. Access is poor so I could not inspect but it it felt like more of an interference fit rather than the hole being threaded
I used one of these, m6x1 90 degree https://www.ebay.co.uk/itm/121996885345 TDi4 - I agree from your picture it looks like the pivot axle is the 'wrong way round' on your LHD. Looks like you have access to the larger locking pin end rather than the smaller end. Like you say you would need to remove and refit in the opposite direction ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 643 ![]() ![]() ![]() |
Earlier pre td5 defenders don’t have a predrilled hole in the pivot pin.
I have always found that squeaking is more likely to come from the top pivot which is unbushed wheras the pedal pivot has bronze bushes, but adding the grease nipple is no bad thing. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2239 ![]() ![]() |
Regarding the grease nipple being a metric 6mm.
I was reading another topic on this subject https://www.defender2.net/forum/topic45191...p;start=30 Blackwolf highlighted the following, which strongly indicates it’s actually a 1/4" UNF grease nipple.
