Home > Maintenance & Modifications > Powder coat removal? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5704 |
Blow lamp and burn it off, has worked best for me before.
Andy |
31st Aug 2013 9:55pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
I used grinding disks when cleaning my winch bumper. It took a while and I went carefully, but the steel underneath is very hard and wasn't damaged by the discs.
The new powder coating has covered very well and so far shows no sign of lifting. Cheers Simon |
31st Aug 2013 10:36pm |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
I cleaned off all the powder coat (and rust) from my roll cage with an angle grinder and a knotted wire brush. Worked brilliantly and stripped it back to bare steel with no damage. Makes a bit of a racket doing it, and the dust gets everywhere so eye, ear and breathing protection is a must.
1st Sep 2013 7:06am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Snap on Crud removal tool is how we do it
1st Sep 2013 7:15am |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
^^Is that the air operated one? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
1st Sep 2013 7:35am |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
http://www.pirate4x4.com/forum/tools-suppl...metal.html
This in your grinder. Reet good bit o kit. |
1st Sep 2013 8:45am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20371 |
Thank-you for the ideas chaps. Bloomin rear ladder is what is doing my nut it. It does it's best to rust despite sorting it only last year. And rivnuts that spin. I wish it wasn't there anyway really but I didn't fit it it was fitted already. $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
1st Sep 2013 9:15am |
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 |
Just going through same thing with my corner bumperettes. Powder coating great until it starts the peel. And you get no warning that it's happening until the corner bits make that depressing ping sound as you're washing it! Had a perfectly sound front bumper apart from the flaking last year, took it to blaster/powder coater and he said the blasting wouldn't touch the pc!! Cheaper to buy new bumper from Craddock at £35. Looking at stainless bumperettes.
1st Sep 2013 9:54am |
1st Sep 2013 9:55am |
Sorry Steve.... Good choice, I've got stainless ones and they are so hard wearing I had the offside one 'reworked' so I could refit it after the swing away fit. Click image to enlarge Linky fingy: http://www.rimmerbros.co.uk/Item--i-LL1212BMSS If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Sep 2013 10:08am |
Yep (very air hungry as well) |
1st Sep 2013 11:33am |
^^Thanks, thought so. I've got one at work somewhere, not been seen in a while though An engine to TDi for!
1st Sep 2013 1:48pm |
EMPI748 Member Since: 15 Dec 2012 Location: Penicuik, Midlothian Posts: 50 |
I use these:
http://www.ekmpowershop2.com/ekmps/shops/a...s-89-p.asp You can get them for less on ebay especially if you buy bulk, removed all the paint and filler from my Karmann Ghia using 4 of them, key is not to press hard. |
1st Sep 2013 1:56pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
Is stove enamel the best option ?
1st Sep 2013 3:05pm |
