Home > Maintenance & Modifications > Powder coat removal?
I have yet again bits that are powder coated that has it peeling off and starting to rust. Shocked
Powder coat really gets on my nerves. Evil or Very Mad
I really would like to remove it and then get them galvanized or zinc coated and then painted. Not always cheaper I know and I also know blasting will be mentioned but I don't want to be bothered going here and there getting galving and blasting done. (It's also easier said than done if I do my A bar when you only have one vehicle as transport)
I'd like to use mechanical removal (and do it myself) i.e. angle grinder but can't use discs because it'll be to damaging to the actual steel underneath. So perhaps something like a abrasive flap kind of thing?
Ideas would b most welcome. I'd rather use paint as at least I can then touch it up if need be and actually get it corrosion protected first. Rather than powder coated over raw mild steel. Rolling Eyes WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #262770 31st Aug 2013 10:41pm
landy andy
Blow lamp and burn it off, has worked best for me before.
Andy
Post #262772 31st Aug 2013 10:55pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I used grinding disks when cleaning my winch bumper. It took a while and I went carefully, but the steel underneath is very hard and wasn't damaged by the discs.
The new powder coating has covered very well and so far shows no sign of lifting.
Simon
Post #262780 31st Aug 2013 11:36pm
Alex1976
I cleaned off all the powder coat (and rust) from my roll cage with an angle grinder and a knotted wire brush. Worked brilliantly and stripped it back to bare steel with no damage. Makes a bit of a racket doing it, and the dust gets everywhere so eye, ear and breathing protection is a must.
Post #262792 1st Sep 2013 8:06am
Snap on Crud removal tool is how we do it Thumbs Up
Post #262794 1st Sep 2013 8:15am
GUM97
^^Is that the air operated one? An engine to TDi for!
Post #262797 1st Sep 2013 8:35am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
http://www.pirate4x4.com/forum/tools-suppl...metal.html
This in your grinder. Reet good bit o kit.
Post #262813 1st Sep 2013 9:45am
Thank-you for the ideas chaps. Bloomin rear ladder is what is doing my nut it. It does it's best to rust despite sorting it only last year. And rivnuts that spin. Rolling Eyes I wish it wasn't there anyway really but I didn't fit it it was fitted already. Neutral WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #262822 1st Sep 2013 10:15am
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Just going through same thing with my corner bumperettes. Powder coating great until it starts the peel. And you get no warning that it's happening until the corner bits make that depressing ping sound as you're washing it! Had a perfectly sound front bumper apart from the flaking last year, took it to blaster/powder coater and he said the blasting wouldn't touch the pc!! Cheaper to buy new bumper from Craddock at £35. Looking at stainless bumperettes.
Post #262828 1st Sep 2013 10:54am
chipmunk
Post #262829 1st Sep 2013 10:55am
K9F
Off Topic Sorry Steve.... Bow down
Good choice, I've got stainless ones and they are so hard wearing I had the offside one 'reworked' so I could refit it after the swing away fit.
Linky fingy: http://www.rimmerbros.co.uk/Item--i-LL1212BMSS If you go through life with your head in the sand....all people will see is an ar5e!!
Post #262834 1st Sep 2013 11:08am
Yep Thumbs Up (very air hungry as well)
Post #262848 1st Sep 2013 12:33pm
GUM97
^^Thanks, thought so. I've got one at work somewhere, not been seen in a while though Laughing An engine to TDi for!
Post #262872 1st Sep 2013 2:48pm
EMPI748
Scotland 2000 Defender 90 Td5 SW Baltic Blue
I use these:
http://www.ekmpowershop2.com/ekmps/shops/a...s-89-p.asp
You can get them for less on ebay especially if you buy bulk, removed all the paint and filler from my Karmann Ghia using 4 of them, key is not to press hard.
Post #262879 1st Sep 2013 2:56pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Is stove enamel the best option ?
Post #262886 1st Sep 2013 4:05pm
