Home > In Car Electronics > CB Radio wiring advice |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
Ah cheers, didn't notice that!
What's better in your opinion out of these two? http://www.autoelectricsupplies.co.uk/product/303/category/62 http://www.amazon.co.uk/standard-Splash-pr...B004JFRWO4 Cheers An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
15th Dec 2013 6:06pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20466 |
Amazon one bud. No Guts, No Glory.
15th Dec 2013 6:10pm |
Gum,
Not sure what extras you may have fitted already or what your plans are but it could be time to fit one of these perhaps? Makes future additions so much easier. http://www.seamarknunn.com/acatalog/blue-s...tAodPjcAIg Some pictures have been cleared out but the fitting details are contained herein.... http://www.defender2.net/forum/topic20439-15.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 15th Dec 2013 6:55pm. Edited 1 time in total |
15th Dec 2013 6:51pm |
Mal, he mentioned on the previous page there isn't enough room in the battery box as I suggested a similar solution.
Could be located elsewhere but not worth the hassle really I guess. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Dec 2013 6:53pm |
Missed that about the twin setup, nevertheless a Blue Sea would fit under the driver's seat. It's not that big. On a Puma it would also fit in the same panel where your fuses and relays are kept under the dash but on the passenger side, there's bags of room in there. Not sure on Gum's model though? If you go through life with your head in the sand....all people will see is an ar5e!!
15th Dec 2013 6:59pm |
I'm on a Tdi Mal, and I've got a fuel tank under my drivers seat I'm pretty much done with electrical accessories/additions, so I don't really need another fuse box to be honest! Thanks for the idea though!
Ring terminals ok for connecting to battery terminal? Or is there a better solution? Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
15th Dec 2013 7:07pm |
Some of which like the winch was used last when?
15th Dec 2013 7:12pm |
15th Dec 2013 7:26pm |
Ring tongues are fine or if you've a mega fuse fitted a ring tongue connected to that is even better. If you go through life with your head in the sand....all people will see is an ar5e!!
15th Dec 2013 7:27pm |
Excellent! Thank you all for the advice Let the wiring commence! An engine to TDi for!
15th Dec 2013 7:43pm |
