Home > In Car Electronics > CB Radio wiring advice
Page 2 of 2 <12
GUM97
Ah cheers, didn't notice that!
What's better in your opinion out of these two?
http://www.autoelectricsupplies.co.uk/product/303/category/62
http://www.amazon.co.uk/standard-Splash-pr...B004JFRWO4
Cheers Thumbs Up An engine to TDi for!
Post #290558 15th Dec 2013 6:06pm
Amazon one bud. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #290561 15th Dec 2013 6:10pm
GUM97
What's the best way to connect to the battery terminal? Using a Ring Terminal? An engine to TDi for!
Post #290572 15th Dec 2013 6:47pm
K9F
Gum,
Not sure what extras you may have fitted already or what your plans are but it could be time to fit one of these perhaps? Makes future additions so much easier. Thumbs Up
http://www.seamarknunn.com/acatalog/blue-s...tAodPjcAIg
Some pictures have been cleared out but the fitting details are contained herein....
http://www.defender2.net/forum/topic20439-15.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #290576 15th Dec 2013 6:51pm
Mal, he mentioned on the previous page there isn't enough room in the battery box as I suggested a similar solution.
Could be located elsewhere but not worth the hassle really I guess. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #290578 15th Dec 2013 6:53pm
K9F
Missed that about the twin setup, nevertheless a Blue Sea would fit under the driver's seat. It's not that big. On a Puma it would also fit in the same panel where your fuses and relays are kept under the dash but on the passenger side, there's bags of room in there. Not sure on Gum's model though? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #290580 15th Dec 2013 6:59pm
GUM97
I'm on a Tdi Mal, and I've got a fuel tank under my drivers seat Wink I'm pretty much done with electrical accessories/additions, so I don't really need another fuse box to be honest! Thanks for the idea though!
Ring terminals ok for connecting to battery terminal? Or is there a better solution?
Pete An engine to TDi for!
Post #290581 15th Dec 2013 7:07pm
Some of which like the winch was used last when? Whistle
Rolling with laughter TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #290584 15th Dec 2013 7:12pm
GUM97
Embarassed Embarassed Whistle An engine to TDi for!
Post #290596 15th Dec 2013 7:26pm
K9F
Ring tongues are fine or if you've a mega fuse fitted a ring tongue connected to that is even better. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #290597 15th Dec 2013 7:27pm
GUM97
Excellent! Thank you all for the advice Bow down Let the wiring commence! An engine to TDi for!
Post #290602 15th Dec 2013 7:43pm
Page 2 of 2 <12
