Home > Maintenance & Modifications > heated side mirrors
JohanH
Norway 2008 Defender 110 Puma 2.4 SW Stornoway Grey
heated side mirrors
hello,
I am tired of not seeing anything from the side mirrors when driving in town. While I do not want to scrape off the ice and risk scraching them, I'd like to install heated mirrors. Does anybody know know if there is such a kit for sale to the Puma?
Merry Christmas from Helsinki! Defender 110 -08
Audi UrQuattro -88
BMW 2000 touring -73
Mercedes-Benz 250 -75
Alfa-Romeo 156 -98
Post #20653 24th Dec 2009 2:59pm
Glynparry25
Hi,
The only kit I know of is the Devon4x4 setup. Only thing that stops me buying it is the price- but it will only be time bfore I end up getting a set.
Hope this helps,
Glyn
Post #20659 24th Dec 2009 3:53pm
Glynparry25
Post #20661 24th Dec 2009 4:03pm
Grockle
Merry Xmas everyone,hope you enjoy it,and Santa brings all you want Smile
that is one neat job,not seen that shown before. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #20683 24th Dec 2009 8:17pm
JohanH
Re: heated side mirrors
Thanks Glynparry25!
wifey got her christmas present today, so now its time to order a set of heated mirrors as a present to Landie!
Cheers,
Johan Defender 110 -08
Audi UrQuattro -88
Alfa-Romeo 156 -98
Post #20690 24th Dec 2009 11:06pm
dgardel
Italy
Glynparry25 wrote:
or
http://la7dja.org/defender/mirror-heating/
Glyn
Bought the glasses, I'm looking time to install...........
I'm thinking about 3 wiring options:
1. I'll connect it to the rear heated window (like my previous Volvo)
2. I'll connect it to the front heated windscreen (mhmmm...)
3. I'll connect it with a dedicated switch (and timer?).... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #20702 25th Dec 2009 9:43am
I fitted heaters to my 110. i bought the stick on pads from a chap in Poland (ebay), i didn't bother with the "kit" as i'm an electrical engineer anyway, so could no-doubt do a better job myself... which i did.
I wired mine into the front heated screen timer (with their own relay) so they only come on for 7 minutes (or so)
I drilled a hole in the back of the plastic of the mirror head, then ran the wired along underneath the "arm" (with some very small cable ties drilled through the aluminium)
Then removed the door hinge, drilled a hole through the door so i could get the cable "inside" the door.
Then used the genuine rubber tubing for doors with electric windows/CDL, ran the cables up into the bulkhead then down to the battery box where the relays live.
Post #20707 25th Dec 2009 11:10am
dgardel
Italy
[1] Then removed the door hinge, drilled a hole through the door so i could get the cable "inside" the door.
Then used the genuine rubber tubing for doors with electric windows/CDL, ran the cables up [2] into the bulkhead then down to the battery box where the relays live.
this is my "focal" point....
[1] could you detail me better where drilled the door? have you photos.....
[2] where bulkhead routing exactly? have you used a "probe" for routing the cables....
Thanks
Daniele Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #20718 25th Dec 2009 8:04pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
dgardel wrote:
Glynparry25 wrote:
or
Glyn
Hi dgardel, with this kit they will provide only the screen or the morror complete?
Hoe is the quality?like OE? Matteo
Defender 110 Td4 SE MY 09
Post #21486 7th Jan 2010 3:50pm
dgardel
Italy
Bomber82 wrote:
dgardel wrote:
Glynparry25 wrote:
or
Glyn
You can buy or the heater (it's like a adhesive with heater film) or the complete glass (choose the convex type).
It's very similar to the OEM realizations and they work well.
I bought this one and they are ok.....
the difficult part is make e good job for the cable routing across the door..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21488 7th Jan 2010 4:19pm
