Home > Puma (Tdci) > Would like a "DPF - is regenerating" - light in th
landybehr
Hi,
while the DPF is behaving fine and I couldnīt tell there was one (but itīs a ī12MY so I can be sure) and I never got the orange or even red warning light, I would be quite fond of a warning light that tells me that the ECU is doing a regerenation right yet.
Point is, the 2.2 is due to the second service at 20.000km. And the oil level is a few but noticeable mmīs above the max. mark on the dipstick. So there must be considerable amount of Diesel in the engine oil. [Donīt like].
The current software version was flashed to the ECU 5.000km ago. Maybe that it helps in this matter.
But I understand that the regeneration takes place periodically. And if it couldnīt be completed, because e.g. the engine was stopped, it will start again at the next opportunity. So .. if I knew that the vehicle regenerates I could continue driving or switch to a route which suits the regeneration better. And thus limitig the contamination of the engine oil in the end.
I think the manufacturer preferred to let the driver unaware of anything that has to do with a DPF. But I would like to know. We have to take what we get, not?
Post #259744 18th Aug 2013 9:50pm
keith
Regen is every 400 miles for me and operates at 890 degrees .
Post #259760 19th Aug 2013 5:33am
landybehr
I thinks that is what the workshop manual tells me too.
But in real conditions it could happen that at mile 400 the regeneration starts but cannot be completed, because you shut off the engine at mile 403. Next day you go shopping, once the engine is warm enough and youīre driving fast enough it starts again. Before itīs completed you arrived and shut the engine off again. On the way home same thing happens.
So there are 2-3 attemps and then one completed regeneration. And the more regen the more diesel in the engine oil.
Iīd like any sign of "recognition" that the vehicle just tries to regen,
Post #259763 19th Aug 2013 6:33am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
hello,
even if no problem until today, I would also be interested to know when it happen for the same reason as descripted by landybehr
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #259799 19th Aug 2013 9:17am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Can soneone explain why the regen process might add diesel to the oil? Thanks,
John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #260366 21st Aug 2013 4:31pm
landybehr
Regeneration means that the exhaust gas temperatures shall be raised. This because with normal driving the exhaust gas isnīt necessarily hot enough to burn the filtred particles and thus not allways passively clean the filter.
To do so there is additional Diesel injected after the "main bang" in the cylinder already has taken place. Kind of "afterburner". IIRC the fuel consumption raises to twice the usual amount in this condition. Itīs only small amount of Diesel that is washed away from the cylinder walls by the piston rings and then finds itīs way into the oil sump. But one adds to the other ...
The Dealer just changed the oil of my Dender today. Oil level is now right in the middle of the "XXXXX" mark on the dipstick. Yesterday it has been, say, 2-3mm above the max-level-mark. I donīt know how much the difference between min. to max. means. If it is 1litre then I guess there was 3/4l Diesel in the oil = 10%
Post #260369 21st Aug 2013 4:49pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Same here, though I don't have a DPF in the Defender but have one in the Freelander, but no light their either.
Used to have some issues with which could have been prevented if I knew it did not regenerate often enough.
Luckely solved since then.
Post #260496 22nd Aug 2013 8:29am
leeds
OK, I am not a mechanic but can follow the principle behind the regen programme. Well sort of.
OK can understand that some diesel might enter the oil.
My question would be how much diesel would be required in the oil to cause problems?
Does diesel in engine oil actually cause problems?
OK can understand that contamination in general is not a good idea.
Brendan
Post #260500 22nd Aug 2013 8:51am
gbmud
2005 Defender 110 Td5 HT Belize Green
How do you know when it is regenerating?
Chris
Post #260518 22nd Aug 2013 10:24am
landybehr
Would be interested in the answer, too.
I read that some people can hear the regen. when it happens.
That certainly is not true for me - the Defender is too noisy, resp. the MT tyres are. And/or my ears are too bad.
Anyway, I cannot perceive anything.
A friend who is a mechanic for Audi/VW, once drove an Audi and noticed a hesitation at acceleration/driving. Though Audi claims the driver wouldnīt be bothered by anything related to the regen.
Post #260524 22nd Aug 2013 10:36am
Good question - never felt any difference when driving along that I could attribute to the regen but then I have never been certain when it is actually operating!
Would one of the aftermarket OBD readers be able to indicate this?
Post #260789 23rd Aug 2013 9:52am
landybehr
Say .. wouldnīt a EGT (exhaust gas) temperature gauge help in the matter ?
Post #262771 31st Aug 2013 9:44pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
I have a PLX Kiwi2 WiFi ODB2 connected to the ODB2 port and clearly see it on my iPhone App. That is fine with me. Never forget: cars have owner, Landrover have field service personnel.
Post #263060 2nd Sep 2013 9:16am
Unnecessary quote removed
What info are you getting/looking at to say the DPF is regenerating?
Post #263080 2nd Sep 2013 10:26am
Natlas
Landybehr, we meet again, common interest in this measurement I see.
Ninety Td4, can you translate all those acronyms into simple english so we have some idea what you're talking about?
Thanks,
John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #263228 2nd Sep 2013 8:33pm
