Home > Puma (Tdci) > Warn 9.5Ti Winch on SVX
555SUB
England 2007 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Can a warn 9.5Ti winch be fitted to a SVX as the land rover accessories catalogue says no?
http://landrover.tagworldwide.com/defender...n_OINT.php see page 22
Does anyone know of a SVX with a winch fitted and if so what equipment was used.
SUB
Post #20521 20th Dec 2009 9:16pm
Glynparry25
The reason why it won't fit is because of the steering guard- I had the same problem when fitting a winch to mine and had to downgrade from the SVX steering guard to a standard Mantec item.
Glyn
Post #20525 20th Dec 2009 9:46pm
Not sure why I have a SVX guard on mine with a Britpart winch Bumper and a 9.5ti Thumbs Up
Post #20527 20th Dec 2009 10:06pm
555SUB
What winch and bumper combination have you fitted and do you have any pics you can post? Which guard did you get?
Post #20528 20th Dec 2009 10:07pm
555SUB
FAO Ken
you have a SVX guard fitted to a puma which does not have an SVX grille and light upgrade. Your 110 looks the biz thou
Post #20531 20th Dec 2009 10:11pm
Glynparry25
Land Rover fit Mantec bumpers as part of the kit and that is why they don't fit. Lots of others will.
Glyn
Post #20532 20th Dec 2009 10:11pm
So there you go then a bit of work and your be fine
Post #20543 21st Dec 2009 12:21am
mse
its only where the recovery points are - you will just need to notch them out if its anything like mine Mike
Post #20563 21st Dec 2009 5:32pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Had my ARB bar and guard modified to fit, works well.
Allan
Post #20613 23rd Dec 2009 1:42pm
