Home > In Car Electronics > Improved sound from standard speaker locations?
nickh90
England 1989 Defender 90 V8 Petrol SW Auto Java Black
Hi all,
In the process of adding a new DAB radio, Bluetooth etc etc as well as 4 new speakers and a slim sub. Got as far as an initial sound test last night (without sub) and even with the new speakers its still very tinny and no base! so...
I have added the rear MUD speakers housings and used the original fronts.. now I know the sub will help but is there anything on the market or that I could try and make that would improve the sound?
Or is it back to basics with some MDF trying to make a housing for behind the speakers/trim?
btw, whole vehicle is Dynamat'd.
Nick
Post #258529 14th Aug 2013 6:43am
jimbob7
doh,my bad!
Post #258541 14th Aug 2013 7:23am
nickh90
What did you do??
Post #258556 14th Aug 2013 7:53am
bear100
it makes a huge difference covering the tweeters on the dash with your hand, i have a function on my new head unit to turn the tweeters down, the speakers under the dash are pretty good really, give it a try and cover both tweeters
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #258561 14th Aug 2013 8:11am
farmer giles
you have a v8, why would you need a radio? Wink
does your head unit have a treble and bass control function? (or even a graphic equilizer) then lower the treble in increase the bass if you don't fit the sub. After you fit the sub this may have to be totally reversed by upping the treble setting and lowering the bass setting to compensate for the sub doing its job and to get a balanced sounding audio system.
hope this helps
Post #258575 14th Aug 2013 9:48am
As above. Most Head Units have this function. Thumbs Up KEEP CALM AND Drill ON
Post #258576 14th Aug 2013 9:50am
barbel jim
Boxes is the only way I'm afraid. Crying or Very sad Crying or Very sad Under the dash they have an air space to create sound, bot in the back is minimal. Also enlarging the speakers will make a difference as they will move more air, but hold of until you have rigged the sub up, then you will see what you have to work with. Thumbs Up
Post #258611 14th Aug 2013 12:19pm
