Home > In Car Electronics > Improved sound from standard speaker locations? |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
doh,my bad!
14th Aug 2013 7:23am |
nickh90 Member Since: 19 Oct 2009 Location: Nr Horsham Posts: 196 |
What did you do??
14th Aug 2013 7:53am |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1939 |
it makes a huge difference covering the tweeters on the dash with your hand, i have a function on my new head unit to turn the tweeters down, the speakers under the dash are pretty good really, give it a try and cover both tweeters
2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
14th Aug 2013 8:11am |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
you have a v8, why would you need a radio?
does your head unit have a treble and bass control function? (or even a graphic equilizer) then lower the treble in increase the bass if you don't fit the sub. After you fit the sub this may have to be totally reversed by upping the treble setting and lowering the bass setting to compensate for the sub doing its job and to get a balanced sounding audio system. hope this helps |
14th Aug 2013 9:48am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
As above. Most Head Units have this function. KEEP CALM AND Drill ON
14th Aug 2013 9:50am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
Boxes is the only way I'm afraid. Under the dash they have an air space to create sound, bot in the back is minimal. Also enlarging the speakers will make a difference as they will move more air, but hold of until you have rigged the sub up, then you will see what you have to work with.
14th Aug 2013 12:19pm |
