Home > Td5 > Discovery 2 , Aaaahhhhh!!!
Phantom
Sorry! I understand its not a defender ( I've got two of those as well! ), however........
Brought a d2 a few week ago 86k / 15p with a known engine fault - head leaking fuel into sump, the lack of lubricant scored the cam shaft and numerous other parts so we brought a used engine from a reputable breakers , 71k with supporting paperwork and swapped the lumps over last week. Fires up on the key and drives lovely............except the first 10 seconds she's as flat as a flat thing, no power Sad , then it's like a switch is flicked, revs jump up and she's off! You can run 10 miles, no issues, pulls like a train but if you turn the ignition off, restart the vehicle immediately the faults back......
It's just annoying Sad
Swapped the maf for a known working unit and also ran with the maf disconnected - no different
Swapped the ecu, programmed the injectors - no different
She's got a egr bypass
Checked turbo waste gate action, all fine
Swapped the waste gate control modual - no different
Pulled the map sensor and cleaned - no different
Injector loom dry
Hawk-pro shows no faults
So what am I missing?
Thanks in advance
Lee
Post #258450 13th Aug 2013 7:34pm
landy andy
Strange it's not the MAF. Classic symptoms of a failed one in my experience.
Will think about it and let you know if anything comes to mind.
Good luck
Andy
Post #258451 13th Aug 2013 7:46pm
bob neville
Turbo hose delaminated or split ?
2013 Defender 90 CSW - sold
Post #258452 13th Aug 2013 7:52pm
Fuel pump? giving the correct pressure?
Have you connected the flow & return the right way around? so it's taking some time to purge the system? The pipes aren't too far from each other, so it's possible to do them the wrong way around (ask me how I know...) Laughing
Post #258454 13th Aug 2013 7:56pm
Phantom
Bob
Don't think so, it's only for the first 10/20 seconds then fine, if it was a hose then I guess it would be all the time
Post #258480 13th Aug 2013 9:21pm
Phantom
I'll double check the fuel pipe work tomorrow - hopefully it's that simple Smile
Post #258481 13th Aug 2013 9:23pm
Phantom
Good luck
Andy
So....................its fixed!
No faults on the Hawk Eye pro, checked everything again inc fuelling pipework and found nothing, brought a new OEM MAF, fitted it and fault gone! Yippee! The mad thing is I'd already tried two other ( used ) MAF sensors, both Siemens units and also run with the MAF disconnected, you learn something every day, thanks for all the pointers
Post #260788 23rd Aug 2013 9:45am
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
I have exactly the same in my 03 90, done it ever since i bought her and only recently was i informed that it wasn't a safety feature, likewise mine has been on the diagnostics and shows nothing wrong, after those first few seconds it drives like any other td5 i know of, just a Censored if you are stall on a roundabout as its a steady crawl. having spoken to monster tuning they had the same with their eight wheeler and after replacing all sorts just replaced the ECU. ED
Post #261186 25th Aug 2013 4:00pm
